29649 Discussions
Intel Fortran Compiler "-parallel" Not Working
ash1
Dear Collegues;
I have a serial Fortran code that works fine. Once I compile the same code using ifort -parallel and run it, it gives wrong results and overflow. I would expect that with "-parallel" flag, the Intel compiler is capable of selecting the loops that are safe to parallelize and I should get the exact same results as for the serial code, which did not happen. The even more strange behaviour is that I went ahead and closed all the do loops parallelization in my code using !DEC$ NOPARALLEL, compiled the code using ifort -parallel to make sure that non of the loops was parallelized and then run. Surprisingly, I got the same wrong results and overflow, although the latter action should be exactly equivalent to a serial code.
Is there any one capable of explaining this behaviour or is it just an Intel compiler deficiency.
Greetings.
TimP
A necessary side effect of -parallel is to set -auto, making local arrays dynamic (on stack, by default). If any such arrays aren't initialized, or are over-run at run time, the bad effects are likely to be aggravated. If they should have been declared with SAVE, so that they retain values when the subroutine is out of scope, -auto again is likely to worsen the problem. So, the most likely case is a bug in the program which may not have been evident until the option was changed. One could hope that the static checking -diag-enable sc or the run-time -check could help uncover the problem.
ash1
It looks to be a deficiency in the Intel compiler. A basic rule is that if the serial code is running fine, then using -parallel should yield the same results atless time.
Any Intel developer to pick up this point and discussion ?
Kevin_D_Intel
Given what you described (using !DEC NOPARALLEL), what Tim suggests is plausible and is seen in many first attempts at using auto-parallelization, as is that -parallel (which requires higher-level opts of -O2 or -O3) may have produced incorrect code causing the incorrect results.
So as Tim suggests:
Can you compile with -auto (w/o -parallel) to see if there are any side-effects?
If you compile with -check all and execute, are there any run-time diagnostics reported?
Since you did not indicate your compiler version, if you are not using the most recent 11.1 Update 2 (11.1.067 - Mac OS, 11.1.056 - Linux) it may be worth obtaining and trying. If that does not help then we would appreciate obtaining a reproducing test case if possible.
Ron_Green
What concerns me is that you're starting from a false assumption: "parallel code should give the same answer as the serial code". This is not true.
I would recommend reading this article on "Why doesn't my application always give the same answer"
http://software.intel.com/en-us/articles/consistency-of-floating-point-results-using-the-intel-compiler/
This discusses optimization but many of the same arguments hold true for parallel optimizations. As a short example, the order of calculations performed in a reduction is quite different between a serial and parallel case.
ron
