Intel Fortran Compiler
HB7
Hi everyone,
I'm a PhD student and I need Intel Parallel XE 2019 for my research. I found out that there used to be a free student version, but now the entire Intel Parallel XE software has been replaced with the oneAPI toolkit. I can't find any information about a student version of oneAPI, and I'm not sure if it will work for me.
Is there any way to get access to Intel Parallel XE 2019?
Thanks!
HB7
I just wanted to update that I copied most lib files both in mkl and another folder to my nmake/codes folder. Now my nmake works.
Steve_Lionel
The oneAPI toolkits are free for everyone. (Support licenses may be purchased.)
HB7
Thank you for your response. I tried using the Intel oneAPI terminal to run my nmake and I am getting this error:
ifort -w -q -o lsdyna.exe couple2other_user.obj dyn21cnt.obj dyn21ueos.obj dyn21umats.obj dyn21ushl.obj dyn21utan.obj dyn21.obj dyn21tumat.obj dyn21umatc.obj dyn21umatv.obj dyn21usld.obj dynrfn_user.obj dyn21umat.obj init_dyn21.obj dyn21em.obj dyn21icfd.obj libdyna.lib libansys.lib shell32.lib user32.lib comctl32.lib comdlg32.lib Iphlpapi.lib gdi32.lib mkl_intel_ilp64.lib mkl_sequential.lib mkl_core.lib -F:1610612736 -link -force -nodefaultlib:msvcrt.lib -ignore:4217 -ignore:4049 -nodefaultlib:vcomp.lib
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.12.0 Build 20240222_000000
Copyright (C) 1985-2024 Intel Corporation. All rights reserved.
ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is now deprecated and will be discontinued late 2024. Intel recommends that customers transition now to using the LLVM-based Intel(R) Fortran Compiler (ifx) for continued Windows* and Linux* support, new language support, new language features, and optimizations. Use '/Qdiag-disable:10448' to disable this message.
ipo: error #11018: Cannot open mkl_intel_ilp64.lib
ipo: error #11018: Cannot open mkl_sequential.lib
ipo: error #11018: Cannot open mkl_core.lib
Microsoft (R) Incremental Linker Version 14.40.33811.0
Copyright (C) Microsoft Corporation. All rights reserved.
-out:lsdyna.exe
-subsystem:console
-stack:1610612736
-force
-ignore:4217
-ignore:4049
dyn21cnt.obj
dyn21ueos.obj
dyn21umats.obj
dyn21ushl.obj
dyn21utan.obj
dyn21.obj
dyn21tumat.obj
dyn21umatc.obj
dyn21umatv.obj
dyn21usld.obj
dynrfn_user.obj
dyn21umat.obj
init_dyn21.obj
dyn21em.obj
dyn21icfd.obj
libdyna.lib
libansys.lib
shell32.lib
user32.lib
comctl32.lib
comdlg32.lib
Iphlpapi.lib
gdi32.lib
mkl_intel_ilp64.lib
mkl_sequential.lib
mkl_core.lib
LINK : fatal error LNK1181: cannot open input file 'mkl_intel_ilp64.lib'
NMAKE : fatal error U1077: 'ifort' : return code '0x49d'
I understand that I am missing some libraries, but I don't know where to find them. I am pretty new to Fortran so it may be a silly problem. Is it because I am using a newer version of the Fortran compiler ?
andrew_4619
Well on my system those are in "C:\Program Files (x86)\Intel\oneAPI\mkl\2024.2\lib\"
AKA C:\Program Files (x86)\Intel\oneAPI\mkl\latest\lib\"
This is no QMKL compile option set on the build command.  That I think triggers the search for the mkl settings which should lead to the lib folder. You need to look at your build script.
Devorah_H_Intel
@HB7 wrote:
Hi everyone,
Thanks!
Here is the direct download link
HB7
