Intel Fortran and MS Visual Studio
Michael7
I just purchased "Intel® Parallel Studio XE 2015 Composer Edition for Fortran, Windows with Rogue Wave IMSL for Windows". Before I begin the installation I would like to ask the community if I also need to purchase Microsoft Visual Studio 2015. and if Yes how do I proceed with the installation. DO I first install Visual Studio and the Intel Fortran or vice-versa.
Thank you very much in advance
You don't have to purchase Visual Studio separately if you will be doing only Fortran development. If no supported VS is seen, the installer will install a VS2013-based Fortran environment.
If you do want to use VS2015, install that first and be sure to "Customize" the install to add the Programming Languages > C++ support.
Michael7
Thanks Steve,
Did you by any chance mean Programming Languages > C++ support or Programming Languages > Fortran support. I just want to make sure.
Best
Michael
I meant C++. Visual Studio itself doesn't know Fortran. But Intel Fortran requires the C++ part of Visual Studio to be installed, and VS2015 leaves it out if you choose the default installation.
