The Intel sign-in experience is changing in February to support enhanced security controls. If you sign in, click here for more information.
27551 Discussions
Intel Fortran exe-modul on PC without Intel Fortan composer
Reidar_L_
How to get an Intel Fortran exe-modul executable on PC:s without Intel Fortran Composer ?
mecej4
Black Belt
An EXE built with IFort needs a number of DLLs to run. These DLLs are usually not present on a PC that does not have compiler packages installed. Some of these DLLs are from Intel, and others are from Visual C++. The simplest way to provide these DLLs on the target PC is to download and install the compiler redistributables package: https://software.intel.com/en-us/articles/intel-composer-redistributable-libraries-by-version .
andrew_4619
with certain build options you can avoid dependencies (static libs and no parallel for example) so you don't need the redistributables.
