29277 Discussions
Intel OneAPI 2025.1.0 crashes for function cachesize
AGG
I have a test program that is crashing with the IFX compiler (Version 2025.1.0 Build 20250317).
Program main
implicit none
integer n
n=cachesize(1)
print*,n
end Program main
Compiling on a Win 10 pro machine using Intel OneAPI command prompt with VS 2019.
error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
n=cachesize(1)
compilation aborted for test_cachesize.f90 (code 3)
Any help would be appreciated. Thank you
JohnNichols
Valued Contributor III
No it is a bug in IFX, I tried it several ways.
AGG
Thank you. I'll see if I can report it.
Devorah_H_Intel
Thanks for report this to us. I have escalated this to our compiler engineering for a fix.
AGG
@Devorah_H_Intel, thank you very much!
JohnNichols
Oh, sweet 2026 we await the new Fortran Treasure.
