Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
26734 Discussions
Intel Parallel Studio XE 2017 evaluator dll
DavidWhite
Black Belt
Similar to the problems reported for the similarly named topic for XE 2016, I am getting the error message for the evaluator dll.
I am running on Win 7 with XE 2017 using the shell version of VS.
I have done a repair on the install, but this has not resolved the issue.
I have observed that the ForDbg* files are not found in C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Packages\Debugger
Thank you,
David
Xiaoping_D_Intel
I can reproduce the error by installing the compiler on a clean win 7 system and ignoring the "Microsoft Visual C++ 2012 Redistributable* (x86) is not installed" warning message during the installation process. But I can found the ForDbg* files in the "...\Debugger" folder.
Downloading and installing the missing package from Microsoft  https://www.microsoft.com/en-us/download/details.aspx?id=30679. (Note: the x64 version will not resolve the issue.) resolved the error.
Xiaoping Duan
Intel Customer Support
DavidWhite
Black Belt
Thanks.  I also was eventually able to resolve this by installing the extra package.   [I wasn't able to originally because I do not have admin rights on my machine].
David
