29277 Discussions
Intel (R) Visual Fortran compiler XE 19.0.0.117 - 64 bits
theyohan258
Hello, I hope you are all well, I need a favor people and it is how to find this compiler (Intel (R) Visual Fortran compiler XE 19.0.0.117 - 64 bits) to install it since I can't find it anywhere and I need it to run a program made in this version, or if someone knows how to do it.
JohnNichols
Valued Contributor III
You can compile the program in the latest version of oneapi and it should run.  It is difficult to get old compilers unless you are a paid supporter, is my understanding.
There is little standard code written that will not compile in the new compiler.
theyohan258
i need a old version, because the proyect no compil, i want use in PSCAD
