29562 Discussions
Internal compiler error - call to type bound procedure
hs-napa
Compiling the following code gives an internal compiler error with compiler version 11.1.067. The code compiles and works fine with version 11.1.054.
[bash]MODULE BASE_MOD
   IMPLICIT NONE
   PUBLIC :: BASE
   PRIVATE
   TYPE, ABSTRACT :: BASE
      INTEGER :: I
   CONTAINS
      PROCEDURE(IFUNC), DEFERRED :: GET_INTEGER
      PROCEDURE :: CALL_DEFERRED
   END TYPE
   ABSTRACT INTERFACE
      INTEGER FUNCTION IFUNC( THIS )
         IMPORT BASE
         CLASS(BASE) :: THIS
      END FUNCTION
   END INTERFACE
CONTAINS
   SUBROUTINE CALL_DEFERRED( THIS )
      CLASS(BASE) :: THIS
      INTEGER :: I
      I = THIS % GET_INTEGER()
      WRITE(*,*) I
   END SUBROUTINE
END MODULE
MODULE TEST_MOD
   USE BASE_MOD
   IMPLICIT NONE
   PUBLIC :: EXTENDED, NEW
   PRIVATE
   TYPE, EXTENDS(BASE) :: EXTENDED
      INTEGER :: J
   CONTAINS
      PROCEDURE :: GET_INTEGER
   END TYPE
CONTAINS
   INTEGER FUNCTION GET_INTEGER( THIS )
      CLASS(EXTENDED) :: THIS
      GET_INTEGER = THIS % I + THIS % J
   END FUNCTION
   FUNCTION NEW()
      TYPE(EXTENDED) :: NEW
      NEW % I = 1
      NEW % J = 2
   END FUNCTION
END MODULE
PROGRAM TEST
   USE TEST_MOD
   IMPLICIT NONE
   TYPE(EXTENDED) :: T
   T = NEW()
   CALL T % CALL_DEFERRED()
END PROGRAM
[/bash]
>ifort type_extension.f90
Intel Visual Fortran Compiler Professional for applications running on IA-32, Version 11.1 Build 20100806 Package ID: w_cprof_p_11.1.067
Copyright (C) 1985-2010 Intel Corporation. All rights reserved.
fortcom: Fatal: There has been an internal compiler error (C0000005).
compilation aborted for type_extension.f90 (code 1)
The problem seems to be compiling the line 72.
The problem also seems to be connected with the PRIVATE statement at line 41. If the PRIVATE statement is removed the code compiles and works.
BR,
-Heikki
pbkenned1
I can reproduce the ICE. Thanks for reporting this, I'll file a bug report with the developers.
Patrick Kennedy
Intel Developer Support
pbkenned1
This has been reported to compiler engineering as defect #DPD200161643. I'll keep this thread updated with any developments. The sameissue also exists in the v12.0 compiler.
Patrick
pbkenned1
This issue is fixed in Composer XE update #3. The update #3 packages are:
l_fcompxe_2011.3.174 (Linux)
w_fcompxe_2011.3.175(Windows)
m_fcompxe_2011.3.167 (Mac OS X)
Patrick
