29375 Discussions
Internal compiler error with lock/unlock
Arjen_Markus
I have run into an ICE with the program below. The compiler version I use is: Intel Fortran 12.0.3 under Linux. The program may not be correct, but the compiler does not give any message, except for the ICE.
Arjen
! primes_coarrays.f90 --
! Determine the first 1000 primes - using coarrays
program primes_coarrays
use, intrinsic :: iso_fortran_env, only: lock_type
implicit none
type(lock_type), codimension
  • :: primes_lock
  • integer, dimension(2), codimension
  • :: range
  • integer, dimension(1000), codimension
  • :: prime
  • integer, codimension
  • :: number_primes
  • logical, codimension
  • :: new_results
  • :: new_task
  • :: ready
  • ready = .false.
    new_results = .false.
    new_task = .false.
    number_primes = 0
    range(2) = 0
    ! Create tasks in image 1 and handle them in all images
    do while ( .not. ready )
    if ( this_image() == 1 ) then
    call add_task
    endif
    call get_task
    enddo
    write(*,'(10i5)') prime
    contains
    ! Subroutine to post a new task (consisting of a
    ! range of integers in which to look for primes)
    ! Loop over the images to see which one wants a
    ! new task
    subroutine add_task
    integer :: i
    do i = 1,num_images()
    if ( .not. new_task ) then
    range(1) = range(2) + 1
    range(2) = range(2) + 100
    range = range[1]
    new_task = .true.
    endif
    enddo
    end subroutine add_task
    ! Subroutine to get a task and search for
    ! primes inside the new range
    subroutine get_task
    integer, dimension(100) :: new_prime
    integer :: lower
    integer :: upper
    logical :: isprime
    logical :: got_task
    integer :: np
    integer :: i
    integer :: j
    integer :: residue
    integer :: maxindex
    got_task = .false.
    np = 0
    if ( new_task ) then
    lower = range(1)
    upper = range(2)
    new_task = .false.
    got_task = .true.
    endif
    if ( got_task ) then
    write(*,*) 'Range: ',lower, upper, this_image()
    do i = lower,upper
    isprime = .true.
    do j = 2,int(sqrt(real(i)))
    residue = mod(i,j)
    if ( residue == 0 ) then
    isprime = .false.
    exit
    endif
    enddo
    if ( isprime ) then
    np = np + 1
    new_prime(np) = i
    endif
    enddo
    endif
    ! Now put the results in image 1
    lock( primes_lock )
    maxindex = min( size(prime) - number_primes[1], np )
    prime(number_primes+1:number_primes+maxindex)[1] = &
    new_prime(1:maxindex)
    number_primes[1] = number_primes[1] + maxindex
    ready[1] = number_primes[1] >= size(prime)
    unlock( primes_lock )
    endif
    end subroutine get_task
    end program primes_coarrays
    jimdempseyatthecove
    Arjen,
    This is a stab in the dark as I do not have a current version of IFV supporting coarrays.
    I notice you have:
    use, intrinsic :: iso_fortran_env, only:lock_type
    And in the contained subroutine get_task you use lock(primes_lock) and unlock(primes_lock).
    get_task does not have implicit none, as to if this makes a difference I cannot say.
    However, I can say that although you are using intrinsic :: iso_fortran_env, only:lock_type, you are not using the declarations for lock and unlock. Meaning lock and unlock may not be fully declared to the compiler, in particular the calling interface and/or if they are intrinsic or not.
    as to if adding lock and unlock to
    use, intrinsic :: iso_fortran_env, only:lock_type, lock, unlock
    I have no way of testing this here.
    Jim Dempsey
    This has nothing to do with the USE - I can reproduce the problem and will report it to development.
    Issue ID is DPD200169012. Compiling with -O0 avoids the ICE, but it is not clear to me if the program works correctly then. I find that the DO WHILE (.NOT. READY) loop never terminates and the program goes CPU-bound. I have not studied it enough to see if the code has a bug.
    Arjen_Markus
    Steve,
    I am pretty sure it does contain bugs ;). Sofar I was able to get it to work somewhatby commenting
    the lock/unlock statements. With this option I should now be able to make it work properly. I am at
    this point not interested in getting the ultimate performance - the program is a mere toy that I use
    to get a feeling for coarrays (and to illustrate their practicaluse).
    Arjen
    Arjen_Markus
    Jim,
    I took the use statement from John Reid's article in the Fortran Forum, but as lock and unlock
    are _statements_, not subroutines, the compiler should know about them without the use statement,
    even if the proper argument type comes from elsewhere.
    Arjen
    jimdempseyatthecove
    Arjen,
    Yes, I understand lock and unlock are not subroutines or functions. Instead they are statement keywords which I assumed (incorrectly) the declarations come in as an intrinsic with a USE, specifically the USE that brought in the lock type. Not having the latest IVF, are lock/unlock brought in by way of option switch? If so, then why isn't the lock type declared in that manner as well? (like INTEGER, ... are)
    Jim
    Arjen_Markus
    I do not know - I simply followed John Reid's article, as that is my authorative text at the moment.
    To use coarrays I do have to use the -coarrays option to the compiler. It does seem a bit odd that
    you have bring the lock_type via a separate statement.
    Arjen
    The need for the -coarray switch in order to use any of the coarray-related features is an "implementation expediency". In an ideal world it would not be needed and omitting the switch would allow you to use the features (including LOCK, CRITICAL, etc.) in a single-image environment. It would have required a lot more work to offer that alternative and we chose not to. Perhaps someday.
    Yes, LOCK_TYPE must be imported from ISO_FORTRAN_ENV - LOCK is a statement. The standards committee wanted to avoid breaking programs by adding a new intrinsic type. ISO_FORTRAN_ENV is, technically, an intrinsic module that requires the programmer to explicitly request its use.
    jimdempseyatthecove
    Steve,
    If you take notice of the original source code file the file contained
    use iso_fortran_env, only:lock_type
    IOW it shouldn't have included lock nor unlock intrinsic keywords (assuming they are declared in iso_fortran_env). Meaning user had a programming error .AND. the compiler behaved as if lock and unlocked were sucked in in violation of the only clause.
    What I am guessing here is the intrinsic keywords were somehow defined as external*** but the calling convention of the INTERFACE somehow did not also come in to play. IOW lock/unlock being called with incorrect calling interface.
    Please note that this is speculation as I cannot reproduce the problem.
    This is why I had asked that the OP add lock and unlock to the only clause.
    If this corrects for the problem then this is indicative of my assumption being correct.
    Jim Dempsey
    LOCK and UNLOCK are statements, not module procedures. I could reproduce the problem easily and in fact cut it down to about five lines.
    Arjen_Markus
    I have improved the program and it is producing the results I expected, except that it does not
    stop - despite the use of a STOP statement and the output showing that all threads (8 in total) have reached
    the end of the program.
    Below you find my updated version.
    Any idea what I am doing wrong?
    Arjen
    implicit none
  • :: primes_lock
  • integer, dimension(2) :: range_priv
  • :: range
  • :: prime
  • :: number_primes
  • :: new_results
  • :: new_task
  • :: ready
  • ready = .false.
    new_task = .false.
    number_primes = 0
    range_priv(2) = 0
    call add_task
    endif
    sync all
    call get_task
    enddo
    endif
    write(*,*) 'Image done:', this_image()
    sync all
    stop
    contains
    ! new task
    subroutine add_task
    integer :: i
    range_priv(1) = range_priv(2) + 1
    range_priv(2) = range_priv(2) + 100
    range(:) = range_priv(:)
    new_task = .true.
    write(*,*) 'Assign', i, range_priv
    endif
    enddo
    subroutine get_task
    integer :: lower
    integer :: upper
    logical :: isprime
    integer :: np
    integer :: i
    integer :: j
    integer :: residue
    integer :: maxindex
    np = 0
    lower = range(1)
    upper = range(2)
    ! Determine what primes we have in this range
    do i = lower,upper
    isprime = .true.
    residue = mod(i,j)
    isprime = .false.
    exit
    endif
    enddo
    if ( isprime ) then
    np = np + 1
    new_prime(np) = i
    endif
    enddo
    write(*,*) 'Found:', np, ' primes'
    write(*,'(5x,10i5)' ) new_prime(1:np)
    lock( primes_lock[1] )
    number_primes = number_primes[1]
    write(*,*) 'Storing primes:', number_primes, np, this_image()
    maxindex = min( size(prime) - number_primes, np )
    number_primes[1] = number_primes + maxindex
    ready = number_primes[1] >= size(prime)
    if ( ready ) then
    ready = .true.
    enddo
    endif
    ! We are done - get a new task, if any
    new_task = .false.
    write(*,*) 'Done - new task:', this_image(), ready
    unlock( primes_lock[1] )
    endif
    write(*,*) 'Done?', this_image(), ready
    jimdempseyatthecove
    Try inserting "sync all" in front of "do while(.not. ready)".
    This is because without sync all, you have a data race condition with "new_task = .true." in add_task (run by 1st thread) against "new_task = .false." in program prior to call new_task run by ancillary threads.
    IOW "new_task[2] = .true." could occur prior to thread 2 issuing "new_task = .false."
    Jim Dempsey
    Try using ERROR STOP instead of STOP.
    Arjen_Markus
    Ah, true! Thanks - I will experiment with getting rid of the "sync all" inside the do-while loop,
    as I do not think it should be necessary.
    Arjen
    Arjen_Markus
    No, the program still hangs.
    Arjen
    jimdempseyatthecove
    When you force a break all - what is happening in each of the threads?
    Jim
    Arjen_Markus
    In the output I see thefinal message from all threads. So as far as I can tell, all threads have left
    the do-loop and are executing the STOP statement.
    Arjen
    jimdempseyatthecove
    Let's do some diagnostics
    In the main program, at end you have
    sync all ! or you had sync all
    stop ! or error stop
    Insert a WRITE(*,*) "passed sync all"
    between sync all and stop
    This should let you know if the program is hanging on thw sync or on the stop
    (leave the former write in front of the synch all too)
    if all threads pass the final sync all then consider:
    a) remove STOP and let threads fall out of program END (past contains)
    b) insert
    do while(this_image() .ne. 1)
    call sleepqq(1)
    end do
    call exit(0)
    Try a) first
    Jim Dempsey
    Arjen_Markus
    Hi Jim,
    I verified that all threads pass the sync all statements, so then I moved on to possible solution a.
    That did not help.
    Then I applied possible solution b.That does not help either! The program simply keeps running,
    that is: it "hangs" in the call to "exit", as a print statement after that does not get executed.
    Arjen
    jimdempseyatthecove
    Arjen,
    Then what happens if you call abort()?
    Not that you want to use abort(), but it may get you by while Intel investigates the problem.
    If abort terminates the app you may have to add statements to flushbuffered I/O too.
    If you are curious and have the C runtime library source code available, you could re-edit the program wo the way it should work then debug step out of the main program (for each thread) and see where the hangup is occuring.
    Jim Dempsey
