Internal compiler error
Walt_Brainerd
I recently tried version 13.1 and found the nice result that
my attempts at using coarrays
   www.fortran.com/13_heat4.f90   for example
run faster than with 12. That is good news.
Also got the strange result following (Yeah, -v is not
legal, but I usually don't get a compiler error on legal code :-).
Running W7-64 on a 2-core i3 laptop.
$ ifort -v
Intel(R) Visual Fortran Intel(R) 64 Compiler XE for applications running on Inte l(R) 64, Version 13.1.1.171 Build 20130313 Copyright (C) 1985-2013 Intel Corporation.  All rights reserved.
ifort: command line warning #10006: ignoring unknown option '/v'
ifort: internal error: Assertion failed (shared/driver/driver.c, line 370)
Even better, you got an ICE compiling nothing at all. I can reproduce this. Even though the driver says that /v is ignored, it seems to do something anyway in many cases.
Walt_Brainerd
Thanks for the response. Good to hear from you.
Glad to know it wasn't my stupidity this time.
Walt, you should know by now that an "internal error" is always a product bug, no matter what you did to trigger it. From what I can see, this error occurs only if there are no source files on the command line. BTW, on Windows the option you want is /logo, but that is on by default.
This has been fixed for a release later this year. Thanks for reporting it.
