Community
cancel
Showing results for
Search instead for
Did you mean:
Highlighted
Introductory videos/training for VS and Fortran
Colleagues,
We have a new team member who could profit from some introductory/overview material regarding Visual Studio and the Fortran compiler integration: building a new project (solution), VS editing and exe generation process, and so on. Tutorials (explained step by step) or Videos. Can anyone make some recommendations?
Thanks in advance,
David
Highlighted
Black Belt Retired Employee
A "Getting Started" guide is
A "Getting Started" guide is installed along with the compiler. You can find it at [install-dir]\documentation_2017\en\ps2017
There aren't videos at present.
Steve (aka "Doctor Fortran") - https://stevelionel.com/drfortran
Highlighted
Valued Contributor III
Quote:Steve Lionel (Ret.)
Steve Lionel (Ret.) wrote:
.. There aren't videos at present.
Steve.
Are videos on YouTube including some which are based on your presentations legit?  If yes, these could be a place to start for OP.
https://youtu.be/xwiI4Ndhb4M
Highlighted
Huh - did not realize someone
Huh - did not realize someone had uploaded those to You Tube. They're on the Intel site somewhere...  That video assumes some basic familiarity with the concepts. A long time ago I did an introductory video based on VS2005 - while it would still be good, the tutorial pretty much walks you through the steps.
Steve, I had a vague memory
Steve, I had a vague memory of that webinar you did but could not find a record of it.  The UTube upload (https://youtu.be/xwiI4Ndhb4M) is only fair quality, and the 1st part is badly chopped. Do you know if the original is still around?  I cannot find it.
David
Highlighted
The original is at Learn to
The original is at Learn to Be An Intel Visual Fortran Power User! but that particular page experiences some sort problem and does not fully load. I reported the issue to the IDZ team.
