This is talked at here Trying to rebuild application with .bat files - Intel Community
To make it simple, I made this small program:
!e5082.for
INTEGER STOPPOINT
DIMENSION STOPPOINT(:,:,:)
ALLOCATABLE :: STOPPOINT
integer ALLOERR
integer I
ALLOCATE (STOPPOINT(1:4,1:3,0:5),STAT=ALLOERR)
I=1
STOPPOINT(1:4,1:3,0:I)=0
end
Compile it gives an error:
D:\r>ifort -c e5082.for
Intel(R) Fortran Intel(R) 64 Compiler Classic for applications running on Intel(R) 64, Version 2021.1 Build 20201112_000000
Copyright (C) 1985-2020 Intel Corporation. All rights reserved.
e5082.for(8): error #5082: Syntax error, found '=' when expecting one of: :: ) , : * <END-OF-STATEMENT> ; . % (/ + - ] /) . ' ** / // > ...
e5082.for(8): error #6911: The syntax of this substring is invalid. [POINT]
compilation aborted for e5082.for (code 1)
But if I change the variable name from StopPoint to STONT, the compiler then has no complaint.
INTEGER STONT
DIMENSION STONT(:,:,:)
ALLOCATABLE :: STONT
integer ALLOERR
integer I
ALLOCATE (STONT(1:4,1:3,0:5),STAT=ALLOERR)
I=1
STONT(1:4,1:3,0:I)=0
end
The problem seems that you can not use STOP to start a variable name. STOPa has the same error.
Cheers,
Cean
Hi
STOP is a statement so the compiler complains from POINT
Syntax of STOP statement
STOP [string]
In Fortran there is no reserved word but the syntax implies the meaning so a line beginning by STOP is a STOP statement.
Another exemple
DO I=1.2
is legal (affecting 1.2 to DOI variable because spaces are ignored)
DO I=1,2
is a loop statement
I do not agree that this is a fixed vs. free form issue. Indeed, I wrote about this topic in Doctor Fortran in "No Reserve" - Doctor Fortran (stevelionel.com)
The compiler has ways of disambiguating statements that start with a statement keyword but aren't those statements. In this case, the appearance of the equal sign or parenthesis is a clue that this is NOT a STOP statement. (I spent a lot of time in the VAX FORTRAN statement classifier code.)
My guess is that when Intel implemented the Fortran 2018 enhancements to STOP to add the optional ", QUIET=expression", the programmer was not careful enough. This is a compiler bug.
That said, fixed form should be avoided on general principles in new code.
To be clear the error only occurs in fixed form is compiles OK in freeform. It seems the Fortran parser is getting confused.
To emphasize: This is the case with fixed form! In fixed form spaces (except in strings) are irrelevant. So, as GVautier indicates, the compiler recognizes the word STOPPOINT as a statement "STOP POINT".
One solution: use free form
