29487 Discussions
Is it a bug in ifort 11.0.081 for linux by using OMP
yeg001
I make a program as follow. It worked fine. But it gaves wrong result if compiled with openmp.
Before call:ABCD
in subroutine, before parallel:ABCD
forrtl: severe (174): SIGSEGV, segmentation fault occurred
[cpp]subroutine para_test(get)
!$ use omp_lib
    implicit none
    character(len=*), intent(in) :: get
    write(*, *) "in subroutine, before parallel:", get
!$OMP parallel firstprivate(get)
!$OMP critical
    write(*, *)"string:", get
!$OMP end critical
!$OMP end parallel
    end subroutine para_test
program main
    implicit none
    character(len=10) :: get = "ABCD"
    write(*, *) "Before call:", get
    call para_test(get)
    stop
end[/cpp]
It seems the problem comes from the subroutine para_test(get), 'len=*'. If a explixit length was given(len=10) tocharacter variable, it is fine.
Thecharacter variable 'get' is a dummy argument in subroutine. It is not necessary to know the length of the character argument when the subroutine is compiled. So, i think that is a bug.
Ron_Green
There is a partial fix for this coming in the version 11.1 compiler, which is currently in beta testing. I have confirmed the fix in this beta compiler. I modified your example a little to get more information out, note that the results are better, but there is still a new bug to enter:
!$ use omp_lib
    implicit none
    write(*, *) "trimmed length is ", len_trim(get)
    write(*,* ) "len it ", len(get)
!$OMP critical
!$OMP end critical
!$OMP end parallel
program main
     implicit none
     call para_test(get)
     stop
end
[/cpp]
And the 11.1 beta produces:
./omperr
Before call:ABCD
trimmed length is 4
len it 10
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
What's interesting is that the firstprivate appears to copy the string but we're losing the trimmed length. Adding a little more information inside the loop:
[cpp]!$OMP parallel firstprivate(get)
!$OMP critical
    write(*, *) "len get is ", len(get)
!$OMP end critical
!$OMP end parallel
[/cpp]
and the results:
[cpp]Before call:ABCD
 trimmed length is            4
 len is          10
 string:ABCD    ??
 trimmed length is           10
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
[/cpp]
so you see that the trimmed length information is not copied correctly for the firstprivate vars. I'll open a new bug on this.
ron
Ron_Green
I would agree, this does appear to be a bug. I will start a bug report.
ron
Ron_Green
!$ use omp_lib
    implicit none
!$OMP critical
!$OMP end critical
!$OMP end parallel
program main
     implicit none
     call para_test(get)
     stop
end
[/cpp]
./omperr
Before call:ABCD
trimmed length is 4
len it 10
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
string:ABCD ??
!$OMP critical
!$OMP end critical
!$OMP end parallel
[/cpp]
and the results:
 trimmed length is            4
 len is          10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
 string:ABCD    ??
 len get is           10
[/cpp]
ron
Ron_Green
bug report number is DPD200120407
jimdempseyatthecove
I think what is happening (someone from Intel pipe in to correct me)
is the length of GET is passed in to para_test as an unseen extra argument to the subroutine.
This length is not visible and not specifiable on the FIRSTPRIVATE and therefore not passed into the stack of the superflous thread(s) (non-team master thread). Try this:
!$ use omp_lib
    implicit none
integer :: len_get
len_get = LEN(get) ! or use LEN_TRIM write(*, *) "in subroutine, before parallel:", get !$OMP parallel firstprivate(get) shared(len_get) !$OMP critical write(*, *)"string:", get(1:len_get) !$OMP end critical !$OMP end parallel end subroutine para_test program main implicit none character(len=10) :: get = "ABCD" write(*, *) "Before call:", get call para_test(get) stop end[/cpp]
Jim Dempsey
