Issue with move_alloc intrinsic
Oleg_Butakov
Hello everyone!
I have encountered the following problem with the move_alloc intrinsic:
I am expecting the following code
program strange
    type :: Something
        integer :: data
    end type Something
    class(Something), allocatable :: a, b
    a = Something(100)
    call move_alloc(from=a, to=b)
    a = Something(200)
    print *, a%data, b%data
end program strange
to output '200 100' (which it does with gfortran/pgfortran), but both ifort and ifx crash with the message:
forrtl: severe (122): invalid attempt to assign into a pointer that is not associated
Image              PC                Routine            Line        Source
a.out              00000000004085E6  Unknown               Unknown  Unknown
a.out              0000000000404B2A  Unknown               Unknown  Unknown
a.out              0000000000404862  Unknown               Unknown  Unknown
libc.so.6          00007F65C86ACFD0  Unknown               Unknown  Unknown
libc.so.6          00007F65C86AD07D  __libc_start_main     Unknown  Unknown
a.out              0000000000404765  Unknown               Unknown  Unknown
 I am running Ubuntu 22.10 with ifort version 2021.4.0 and ifx version 2021.4.0 Beta.
Replacement of 'class' with 'type' does not cause the crash.
Regards, Oleg
Barbara_P_Intel
Thanks for the nice reproducer and for the triage tip about changing Class to Type.
I filed a bug report, CMPLRIL0-34514, on your behalf.
In case you are interested, the failure occurs at the
a = Something(200)
statement. We added an ALLOCATED() check after the MOVE_ALLOC. A is not allocated. A should be allocated automatically since it is on the LHS (left hand side) and it is allocatable.
I'll let you know when it is fixed.
andrew_4619
Well that seems like a bug but your usage case seems very strange, in effect you are allocating B as the same size and bounds as A  and afterwards A will be deallocated and B will be allocated but uninitialized. The intended usage of MOVE_ALLOC is to make and existing data structure bigger with only one data copy being needed. If you use STAT or  ERRMSG what do you get?
Oleg_Butakov
Hi Andrew!
'move_alloc' finishes without any error (stat==0).
Crash happens on assignment to the allocatable variable, which was 'from' argument of 'move_alloc' (line 11 of the listing above).
Looks like the internal state of that variable was not completely reset to the deallocated state.
My intended usage of 'move_alloc' is the following (pipeline of stream):
type, abstract :: tOutputStream
end type :: tOutputStream
type, extends(tOutputStream) :: tUnitOutputStream
end type tUnitOutputStream
type, extends(tOutputStream) :: tBase64OutputStream
  class(tOutputStream), allocatable, private :: InnerStream
end type tBase64OutputStream
interface tBase64OutputStream
  module procedure MakeBase64OutputStream
end interface tBase64OutputStream
function MakeBase64OutputStream(innerStream, ...) result(stream)
  class(tOutputStream), intent(inout), allocatable :: innerStream
  type(tBase64OutputStream) :: stream
  call move_alloc(from=innerStream, to=stream%InnerStream)
end function MakeBase64OutputStream
type, extends(tOutputStream) :: tZLibOutputStream
end type tZLibOutputStream
interface tZLibOutputStream
  module procedure MakeZLibOutputStream
end interface tZLibOutputStream
function MakeZLibOutputStream(innerStream, ...) result(stream)
  type(tZLibOutputStream) :: stream
end function MakeZLibOutputStream
stream = tUnitOutputStream(unit)
if (binary) then
  stream = tBase64OutputStream(stream)
  if (compressed) then
    stream = tZLibOutputStream(stream)
  end if
end if
Of course, the code above can be rewritten with pointers, but in my opinion, with allocatables it looks much cleaner (resembles the 'std::unique_ptr' from C++). Please correct me if I am doing something wrong/not in a Fortran-ish way. Thanks!
Regards, Oleg
andrew_4619
stream%InnerStream = innerStream ! stream%InnerStream will be allocated AND get a copy of InnerStream data
deallocate( InnerStream )
Is this what you are trying to do? By default in Fortran on whole array assignment the LHS is automatically allocated or reallocated.
Oleg_Butakov
Technically, yes. But I am assuming that with 'move_alloc' the innerStream is transferred to stream%InnerStream without copying.
Then, e.g., on line:
I assume that the 'stream' is moved inside the newly create instance of 'tBase64OutputStream' (and the 'stream' variable is in the 'deallocated' state), which is moved back into the 'stream'. And this line crashes with ifort.
andrew_4619
OK I understand your usage, I think that is a compiler bug. Maybe some others will comment.
Barbara_P_Intel
a = Something(200)
Barbara_P_Intel
This runtime failure is fixed in the current version of ifort, 2021.7.0. It was released last week as part of oneAPI 2022.3.
Please give it a try!
