Issue with use DFLIB command
sasikumars
I am using VS2005 and Intel 9.1 compiler. I am trying to compile the fortran code using Fortran compiler. I am getting the error "Error in opening the Library module file". Any idea how to fix this issue.
This should work - in VS, select Tools > Options > Intel Fortran and click the ... button next to Include Files. It should have the compiler's INCLUDE folder.
Consider changing DFLIB to one of the IFxxx modules. Look in the documentation for the routines you're using to see which one(s) you need.
Mizanur_R_
I need help to resolve linking error. I am using source code which can compile in DEVELOPER FORTRAN IN VISUAL STUDIO. I am usingIntel(R) Visual Fortran     Package ID: w_fcompxe_2013_sp1.3.202 Intel(R) Visual Fortran Composer XE 2013 SP1 Update 3 Integration for Microsoft Visual Studio* 2012, 14.0.0092.1 to compile the  code. Code has quick window option. Can I still use DFLIB command or I need to use IFPORT, IFCORE and IFQWIN.
I am getting following error. Seems it is not getting library routine.
You can still USE DFLIB. I don't see the error message in your post.
