29427 Discussions
LNK2001: unresolved external symbol .T526__pack
bnm1
Ihave problem inmigrating QwickWin CVF projects (Standard Edition 6.6a ) to IVF.
Converted projects do not link. Build Log:
Linking...
main.obj : error LNK2001: unresolved external symbol .T526__pack
main.obj : error LNK2001: unresolved external symbol .T1747__pack
main.obj : error LNK2001: unresolved external symbol .T2491__pack
main.obj : error LNK2001: unresolved external symbol .T3209__pack
main.obj : error LNK2001: unresolved external symbol .T3748__pack
main.obj : error LNK2001: unresolved external symbol .T4695__pack
fatal error LNK1120: 6 unresolved externals build failed.
Whatare .T526__pack, .T1747__pack,..?
Those are symbols generated by the compiler and you should not be seeing these errors. If you are using the current 9.1.033 compiler and have this problem, please submit a test case to Intel Premier Support.
bnm1
That was my guess.
This is the older Standard Edition version 9.0.2713.2003 (the licence expired 2006/07/11 so I can not install the latest version)
Thank you
Well, 9.0.2713.2003 is not the compiler version, that's the Visual Studio integration version. You should be able to install the 9.1.024 package. I would suggest sending a test case to Intel Premier Support anyway so we can make sure that it isn't still a problem.
