Link errorw
reidar
New User
I am currently trying to convert a QVF project into IVF. I'm using VS2005 along with IVF10.026. I have checked the project properties against the
QW-paint IVF sample, and the in my project looks like:
/OUT:"Debug/CaFeMS1.exe" /INCREMENTAL:NO /NOLOGO /NODEFAULTLIB:"dfconsol.lib" /MANIFEST /MANIFESTFILE:"C:\CALC\CaFeMS-IVF2\debug\cafems1.exe.intermediate.manifest" /DEBUG /PDB:"Debug/CaFeMS1.pdb" /SUBSYSTEM:WINDOWS /ENTRY:"WinMainCRTStartup" kernel32.lib.
Whereas command line for the QW-paint is:
/nologo /Zi /Od /module:"Debug/" /object:"Debug/" /traceback /check:bounds /libs:qwin /dbglibs /c
I have edited a "Custom build step" similar to the QW-Paint, however the Command line in the Linker container doesn't change and I still receive
the same messages, some of them are listed below.
What should I do ?
Error 96  error LNK2005: _flush_nonadv_buffers already defined in libifcoremt.lib(for_m_qqs.obj) dfor.lib
Error 97  error LNK2005: _FStrToCStr@12 already defined in libifcoremt.lib(for_m_qqs.obj) dfor.lib
Error 98  error LNK2005: _CStrToFStr@16 already defined in libifcoremt.lib(for_m_qqs.obj) dfor.lib
Error 99  error LNK2005: __FFunusedqq already defined in libifcoremt.lib(for_m_qqs.obj) dfor.lib
Error 100  error LNK2005: _for_emit_diagnostic already defined in libifcoremt.lib(for_diags_intel.obj) dfor.lib
Error 101  error LNK2005: _for__issue_diagnostic already defined in libifcoremt.lib(for_diags_intel.obj) dfor.lib
Error 102  error LNK2005: _for__io_return already defined in libifcoremt.lib(for_diags_intel.obj) dfor.lib
Error 103  error LNK2005: __cinit already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 104  error LNK2005: _exit already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 105  error LNK2005: __exit already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 106  error LNK2005: __cexit already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 107  error LNK2005: __c_exit already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 108  error LNK2005: __C_Exit_Done already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 109  error LNK2005: __C_Termination_Done already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 110  error LNK2005: __exitflag already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 111  error LNK2005: __wpgmptr already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
Error 112  error LNK2005: __pgmptr already defined in LIBCMTD.lib(crt0dat.obj) libc.lib
You are linking in objects compiled by DVF/CVF. You must recompile all Fortran sources with IVF. A Rebuild should take care of it, unless you are linking to a separate .LIB, in which case that .LIB needs to be rebuilt.
