Linker can't find ISO_FORTRAN_ENV
ender01
Hello all,
Last night I went down a rabbit hole and decided to try to get ArrayVisualizer integrated with VS2008/IVF (11.1.065 [IA-32]). I followed the directions given in the following post:
http://software.intel.com/en-us/forums/showthread.php?t=65273
Lo and behold, the demo program compiled and ran, and I was able to examine arrays in ArrayVisualizer while debugging. Life was good until I tried to recompile the code that I was working on. When I did, I got this message:
error #7002: Error in opening the compiled module file. Check INCLUDE paths. [ISO_FORTRAN_ENV]
Any suggestions?
Rich
That's not the linker, that's the compiler. ISO_FORTRAN_ENV.modintr should be in C:\Program Files\Intel\Compiler\11.1\065\include\ia32 and the INCLUDE path should have this folder (up to "include" - the compiler will add the ia32.)
My guess is that you corrupted the list of "Includes" and I note that, for some reason, that post omits the backslashes in the path. I'll edit it to reinstate them.
Click the Reset All button in that Tools > Options > Intel Fortran > Compilers dialog and carefully add the AV paths as a new line in the list.
ender01
Curioser and curiouser...
I had figured that the backslashes were missing and had added them. The includes were:
$(IFortInstallDir)include
$(IFortInstallDir)include\ia32
$(IFortInstallDir)mkl\include
$(VCInstallDir)atlmfc\include
$(VCInstallDir)include
$(VCInstallDir)PlatformSDK\include
$(WindowsSdkDir)include
"C:\Program Files\Intel\Array Visualizer\include"
Similarly, the executables and libraries were:
$(WindowsSdkDir)bin
$(PATH)
"C:\Program Files\Intel\Array Visualizer\bin"
and
$(VCInstallDir)PlatformSDK\lib\x86
$(WindowsSdkDir)lib
"C:\Program Files\Intel\Array Visualizer\lib"
respectively. Per your recommendation, I hit the reset all button and re-added the paths via cut and paste from the edited post referenced above. No dice. I hit reset all again and did not add the paths and the compilation worked. I then added AV paths one at a time, first to Executables, then to Libraries, and finally to Include, trying the compilation after each update. The addition to the Includes is where the problem is. As soon as I add it, it can no longer find ISO_FORTRAN_ENV and as soon as I remove it, everything is peachy keen again.
Any ideas?
Try it without the quotes.
