Linking Problem
devaborah
My company Woolpert, Inc. purchased the Intel Fortran Compiler Professional Edition for Windows (Incl. Microsoft Visual Studio 2005 Premier Edition) for me. I need it to develop, compile, and run Fortran source codes. I am trying to start with an old source code, last compiled in 2002 using 1998 DIGITAL Visual Fortran Professional Edition.
I have been trying to compile my old Fortran source code and every time get the following error message:
ifort: error #10037: could not find 'link'
We downloaded three versions of the program hoping that one would work.
First download: w_cprof_p_11.0.074.exe
Second download: w_cprof_p_11.0.074_ia64.exe
Final download: w_cprof_p_11.0.074_ia32.exe
So far, I am getting the same error message:
Please help!
Sincerely,
Deva Borah
Exit Visual Studio. Open the folder C:Program FilesIntelDownloadFortranCompilerPro11.0.074installs1033w_cprof_vs2005 Run ppe.exe in that folder. If it offers a "Repair" option, take that, otherwise let it install.
That helped another user.
You did not want the _ia64.exe download but it probably doesn't hurt, other than disk space. That's for Intel Itanium systems.
Are you trying to build a 32-bit or 64-bit application?
devaborah
Steve
Thanks for the prompt reply! I apologize for my delayed response.
I followed the installation instructions above and reinstalled it. When I tried to compile the program again using:
ifort C:W_DWSMDWSMHydroSed.for
it gave the same error:
I alsogot the following information along with the error message:
Intel Visual Fortran Compiler Professional for applications running on IA-64, Version 11.0 Build 20090318 Package ID: w_cprof_p_11.0.074
Our computer staff told me that my computer is fit fora 32-bit application.
Thanks and look forward to yourfurther help!
Deva
Ok, that explains it. Please use the "Fortran Build Environment for Applications running on IA-32" shortcut to start your command prompt session.
devaborah
THANKS A LOT STEVE! IT WORKED
Deva
Great! Now, uninstall the IA-64 compiler so you won't trip over it again. This is for building programs that run on Intel Itanium processors.
devaborah
Thanks Steve! How could I selectively andsafely uninstall the IA-64 compiler?
Deva
You should find a separate entry for it in Add or Remove Programs.
