Linking problem
Clive_J_1
I have a piece of code to call the C function GetAdaptersInfo to obtain the MAC address(es) of the computer.
The (abridged) code that works is
USE IFWINTY
! define Fortran equivalents of required C structures
INTERFACE
  INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)   !                       &
 !&                                              BIND(C, NAME='GetAdaptersInfo')
!DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetAdaptersInfo' :: GetAdaptersInfo
  USE IFWINTY
  INTEGER (LPLONG) :: arg1
  INTEGER (LPLONG) :: arg2
  END FUNCTION GetAdaptersInfo
END INTERFACE
dwRetVal = SIZEOF(AdapterInfo)
iret = GetAdaptersInfo(LOC(AdapterInfo), LOC(dwRetVal))
However, I would prefer to do it the ISO standard way instead of using specific compiler directives so if I have tried changing the code to
USE IFWINTY
USE ISO_C_BINDING
INTERFACE
  INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)                          &
  USE IFWINTY
  USE ISO_C_BINDING
END INTERFACE
but then it fails in the linker step cannot resolve _GetAdaptersInfo
What am I doing wrong.
TIA
Clive
IanH
Are you compiling for 32 bit windows?  If so, the Windows API calls are not "C compatible" and you therefore cannot use BIND(C).
(Hence the use of the STDCALL directive in your original code.)
Clive_J_1
Yes it is 32bit windows. Guess I will have to stick with the compiler directives.
Clive_J_1
First of all I apologise for seemingly creating two threads of the same post.
I have done some more research and the problem has been raised before and it is down to the STDCALL directive. Apparently, it is a restriction of Intel Fortran that such procedures may not be linked with BIND(C) so I am stuck with using the compiler directive.
