MAC adress
imeca
Hello friends,
Iwill be grateful if anyone help me to find the mac adress(es) of the PC using only fortran code.
thank you in advance.
Jugoslav_Dujic
Valued Contributor II
Quoting - imeca
Hello friends,
Test...
New forum bug: when you compose the post and the sending fails, when you hit "back" in the browser, your work is lost.
Jugoslav_Dujic
Quoting - Jugoslav Dujic
Test...
So, composing it again:
We had this thread back in 2004:
http://software.intel.com/en-us/forums/showthread.php?t=40833
It lead to this MSDN Visual Basic example:
http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q175472
Note that Intel Fortran now has all the API stuff declared (I verified at least for T_ADAPTER_STATUS), so you won't have to go through the hoops as the original poster back then. Just declare and use the TYPEs and functions.
yamajun2
Quoting - imeca
Hello friends,
Here is my program to get MAC ADDRESS by Fortran.
http://d.hatena.ne.jp/fortran66/20080228
It is wriiten in Japanese, but Isuppose you can guess!
You have to add "iphlpapi.lib" to Linker->Input->Additional Dependencies.
Yamajun
[cpp]PROGRAM MAC
USE ifwinty
IMPLICIT NONE
INTEGER, PARAMETER :: MAX_ADAPTER_DESCRIPTION_LENGTH = 128 !// arb.
INTEGER, PARAMETER :: MAX_ADAPTER_NAME_LENGTH        = 256 !// arb.
INTEGER, PARAMETER :: MAX_ADAPTER_ADDRESS_LENGTH     =   8 !// arb.
TYPE :: IP_ADDRESS_STRING
  CHARACTER (4) :: String(4)
END TYPE
TYPE :: IP_MASK_STRING
END TYPE
TYPE :: t_IP_ADDR_STRING
 INTEGER (LPLONG) :: pNext
 TYPE (IP_ADDRESS_STRING) :: IpAddress
 TYPE (IP_MASK_STRING) :: IpMask
 INTEGER (DWORD)      :: Context
END TYPE
TYPE :: t_IP_ADAPTER_INFO
 INTEGER (DWORD) :: ComboIndex
 CHARACTER (LEN = MAX_ADAPTER_NAME_LENGTH + 4) :: AdapterName
 CHARACTER (LEN = MAX_ADAPTER_DESCRIPTION_LENGTH + 4) :: Description
 INTEGER (UINT) :: AddressLength
 INTEGER (BYTE) :: Address(MAX_ADAPTER_ADDRESS_LENGTH)
 INTEGER (DWORD) :: Index
 INTEGER (ULONG) :: iType
 INTEGER (ULONG) :: DhcpEnabled
 INTEGER (LPLONG) :: pCurrentIpAddress
 TYPE (t_IP_ADDR_STRING) :: IpAddressList
 TYPE (t_IP_ADDR_STRING) :: GatewayList
 TYPE (t_IP_ADDR_STRING) :: DhcpServer
 INTEGER (BOOL) :: HaveWins
 TYPE (t_IP_ADDR_STRING) :: PrimaryWinsServer
 TYPE (t_IP_ADDR_STRING) :: SecondaryWinsServer
 INTEGER (ULONG) :: LeaseObtained
 INTEGER (ULONG) :: LeaseExpires;
END TYPE
INTERFACE
 INTEGER (BOOL) FUNCTION GetAdaptersInfo(arg1, arg2)
 USE ifwinty
 !DEC$ ATTRIBUTES DEFAULT, STDCALL, DECORATE, ALIAS:'GetAdaptersInfo' :: GetAdaptersInfo
 INTEGER (LPLONG) :: arg1
 INTEGER (LPLONG) :: arg2
 END FUNCTION
END INTERFACE
TYPE (t_IP_ADAPTER_INFO) :: AdapterInfo(16)
TYPE (t_IP_ADDR_STRING) :: CurrentIpAddress
INTEGER (DWORD) :: dwRetVal
INTEGER (BOOL) :: iret
INTEGER :: i
dwRetVal = sizeof(AdapterInfo)
iret = GetAdaptersInfo(LOC(AdapterInfo), LOC(dwRetVal))
IF (iret /= 0) STOP 'Error'
DO i = 1, 16
! PRINT *, AdapterInfo(1)%pNext
! PRINT *, AdapterInfo(1)%ComboIndex
! PRINT *, AdapterInfo(1)%AddressLength
 PRINT *, AdapterInfo(1)%Description(1:INDEX(AdapterInfo(1)%Description(1:128), CHAR(0)))
 PRINT '(5(Z2.2,"-"), Z2.2)', AdapterInfo(i)%Address(1:AdapterInfo(i)%AddressLength)
 PRINT *, AdapterInfo(1)%IpAddressList
 IF (AdapterInfo(i)%pNext == NULL) EXIT
END DO
STOP
END PROGRAM MAC[/cpp]
Paul_Curtis
Works very well, thank you.
