Makefile
JohnNichols
Honored Contributor I
Dear Steve:
It is many years since I used makefiles, well actually I was never successful.
I have a new device that has a sample testfile written in C++ as a console application. It has a makesource file as shown in sources.
Of course I want to take the program and turn it into a Fortran program running in Windows, but using the C++ code as is for the moment.
CAn I make a console application in VS with the C++ program?
I realize it is off topic, but the end is to make the USB device readible in Fortran and not C++
JMN
If you have Visual C++ and the referenced libraries, it should be simple. Since you didn't show the C++ code I can't tell for sure if it is intended to be a console application. I do note that the makefile references a usbd.lib which is not standard with the Windows SDK. It looks as if it is part of the Windows CE SDK, which may prevent its being usable on regular Windows.
JohnNichols
Dear Steve:
USBd.lib is part of the WINDDK Programs and it will compile on a 32 bit system. I think.
I enclose the source, it is a console application, I will try it out.
I am trying to read from a USB port and get raw data rather than go through the manufacturer's slow interface.
JMN
