Meaningless compiler error message
DavidWhite
Valued Contributor II
I have a solution space with 7 projects, all Fortran, consisting of some 80 or so source files. Today I changed about 10 lines in one source file, and when compiling the project get the error:
Error: The operation could not be completed
========== Build: 0 succeeded, 1 failed, 6 up-to-date, 0 skipped ==========
Rebuilding make no difference. Before making the code changes, earlier today, I successfully rebuilt the project in Release mode, then changed toDebug mode, rebuilt and ran the project.
It is not helpful to have such an obscure and uninformative error message.
David
DavidWhite
After posting the last message, I was able to resolve the error by closing and reopening VS2005!!!
(For reference, I am using 10.1.024)
David
onkelhotte
New Contributor II
Maybe "cleaning solution" before "rebuilding solution" should help too...
markus
Les_Neilson
Did you look in the build log file ?
Whenever I have had this message it has been due to the resource compiler rc.exe and not the fortran compiler.
Les
