Hi all,
What do you make of the following code test-case? On a RHEL5 setup here compiling this code with ifort (tested with 10.1.022 for AMD64 Linux and with 11.1.038 for AMD64 Linux) results in a memory fault at line 22 (during the array copy). Code executes fine with gfortran 4.2+ and Sun Studio 12. Someone on #fortran@freenode.net tested ifort 11.0 and 11.1 and got no segfault running the testcase but reported that valgrind showed some errors:
==25534== Invalid write of size 4
==25534== at 0x40310E: mytype_module_mp_copy_mytype_ (fhjff.f90:22)
==25534== by 0x4036B2: MAIN__ (fhjff.f90:41)
Is this a bug in the Intel compiler or a problem in the code? Note that doing the array copy in a do or forall statement one 'k' slice at a time seems to work around the bug. Also reducing the size of the array significantly works too.
testcase:
testcase:
[cpp]module mytype_module
type mytype
real, dimension(:, :, :), allocatable :: values
end type mytype
contains
Function copy_mytype(a) result(b)
Implicit None
type(mytype), intent(in) :: a
type(mytype) :: b
integer :: Ni, Nj, Nk
Ni = size(a%values, 1)
Nj = size(a%values, 2)
Nk = size(a%values, 3)
allocate(b%values(Ni, Nj, Nk))
write (*,*) 'about to copy values '
b%values = a%values
write (*,*) 'copy done'
end function copy_mytype
end module mytype_module
program test_mytype
use mytype_module
Implicit None
type(mytype) :: a, b
Ni = 500
Nj = 500
Nk = 50
allocate(a%values(Ni, Nj, Nk))
a%values = 1.
b = copy_mytype(a)
write (*,*) 'done'
end program
[/cpp]
Seems like the -heap-arrays compiler option fixes it for me. I should have read the guide at http://software.intel.com/en-us/articles/determining-root-cause-of-sigsegv-or-sigbus-errors/ earlier!
I'll have to do more research about how ifort uses stack...
The compiler could do a better job at realizing that no temporary array was needed in this case. It is something we hope to improve in the future.
