Memory leak with derived-type allocatables and realloc_lhs
Wukie__Nathan
I have a derived-type with an allocatable array component defined as:
module type_one
    type, public :: one_t
        integer, allocatable :: i(:)
    end type one_t
    public operator (+)
    interface operator (+)
        module procedure add
    end interface
contains
    elemental function add(u,v) result(res)
        type(one_t),    intent(in)  :: u,v
        type(one_t) :: res
        res%i = u%i + v%i
    end function
end module type_one
Compiling with -assume realloc_lhs and executing the addition operation as follows results in a memory leak:
program mem_leak_test
    use type_one
    implicit none
    type(one_t), allocatable    :: a(:), b(:), c(:)
    integer :: i
    allocate(b(4), c(4))
    do i = 1,4
        allocate(b(i)%i(5))
        allocate(c(i)%i(5))
        b(i)%i = 1.0
        c(i)%i = 2.0
    end do
    a = b + c
    print*, a(1)%i
end program mem_leak_test
This was first observed on OS X using ifort v15.0.3 confirmed on Linux ifort 15.0.2. Valgrind --tool=memcheck produces the following:
==3411== LEAK SUMMARY:
==3411==    definitely lost: 60 bytes in 3 blocks
==3411==    indirectly lost: 0 bytes in 0 blocks
==3411==      possibly lost: 0 bytes in 0 blocks
==3411==    still reachable: 1,136 bytes in 16 blocks
==3411==         suppressed: 0 bytes in 0 blocks
This seems related to the following topic:
https://software.intel.com/pt-br/forums/topic/269437
Reproducer is attached.
Wukie__Nathan
I am still able to reproduce this issue in ifort 17.0.1 20161005
Kevin_D_Intel
Yes, sorry, there's been no resolution to this issue yet. We'll keep the post updated when there is.
Wukie__Nathan
I am still able to reproduce this issue with ifort 19
FortranFan
I'll suggest you follow up at Intel OSC: https://supporttickets.intel.com/servicecenter?lang=en-US
