29640 Discussions
Message Error: error while loading shared libraries: libcxa.so.5
clima
Hi everybody!
I'm having a problem when I execute a program in fortran. The error message is this
error while loading shared libraries: libcxa.so.5: cannot open shared object file: No such file or directory
It makes the .exe but It doesn't work. I've already checked de ifortvars.sh file and the LD_LIBRARY_PATH="/opt/intel_ifc_80/lib" is well directed. And the library libcxa.so.5 exists in /opt/intel_ifc_80/lib
I've also searched in this forum but I haven't found a solution yet.
Laurie.
Ron_Green
Hi Laurie,
Wow, a 8.x compiler.
It's probably some odd runtime env problem - hard to say.
You can compile with -static-libcxa and just statically link it.
OR try
ldd foo.exe
and see where it thinks it's getting libcxa.so.5
ron
clima
Sorry, I've forgot to tell you, my compiler is intel fortran 8.1, and running in Fedora Core 6. I've tried to do this: ldd foo.exe but I don't have that executable, or I don't know where to find it. Thanks anyways Laurie
clima
Hi everyone! After many time fighting with this problem I have solved it at last. I've executed the comand env and I've seen that wasn't there. So I've wrote source /opt/intel_ifc_80/bin/ifortvars.sh after that I've executed env again and the LD_LYBRARY_PATH was there now. Then compiled mi program, and the error message about the library was gone. Now I've another error message but I'll research about it better before I ask for help. Thank you!! Laurie
