Messagebox newline
tropfen
i am using a messagebox call (to be correct the xeffort wrapper xmessagebox). i would like to add a line break to start a text in a new line.
From VBA i remember the syntax \\n. I have tested it but it do not work.
A search on the forum has no results.
Thanks in advance
Frank
netphilou31
New Contributor III
Hi Franck,
I think that you need to add a newline character manually in your string to have the correct behavior.
Example : string = "First line" // char(#0A) // "Second line"C
Don't forget the final C to declare that it is an ansi string (i.e. terminated by a null character)
N.B: #0A is the ascii code for LineFeed character
GVautier
New Contributor III
Hello
I think that "c" strings are "interpreted" at compilation time.
So the string "first line\nsecond line"c will integrate a line feed.
Jugoslav_Dujic
Valued Contributor II
Quoting netphilou31
Hi Franck,
Close, but I think that one actually needs CR+LF (char(13)//char(10)) to actually make a linebreak in a message or edit box.
netphilou31
New Contributor III
For what I know,the standard MessageBox function (i.e. from Windows API) works as I mention previously.
I think that the compiler interprets the final C character to transform the string into C string but I think that it does not interprets the characters inside the string.
To Jugoslav: You are problably right, I was not sure if the CR character was mandatory or nor. As far as I remember I get the function working correctly without the CR character but may be that was a side effect.
tropfen
Hello Jugoslav,
could you please add this information in your help file of XEffort for the XMessageBox.
An other question about XEffort. Is there a time line for a IVF 12 Release?
Thanks in advance
Frank
Jugoslav_Dujic
Quoting tropfen
Thanks in advance
Frank
There was, but it is broken. I'm helluva busy, and can't make any promises. :( Your question is duly noted though, and I'll try to find some spare time.
anthonyrichards
New Contributor III
Many times I have used CHAR(10)//CHAR(13) added to MessageBox strings to make them display over more than one line.
The point made about the compiler interpreting C-strings at compile time only applies if it can see ALL the characters in the string at compile time. It cannot and will not 'interpret' the character pair \r\n as an escape sequence unless it can 'see' it, for example in
string='This is a very, very, very long line that I want to\r\nsplit into two lines'c
The terminal C defines the preceding character string as a C-string. This will then be hard coded at compile time with the substitution of the required control characters in place of '\r' and '\n'.
This string can be built at execution time using
splitstring=char(10)//char(13)
string1='This is a very, very, very long line that I want to'
String2='split into two lines'
string3=string1//splitstring//string2//char(0)
with char(0) adding the null terminator required by C-strings for use in Windows API calls such as MessageBox or GetOpenFileName.
If you tried
string3=String1//'\r\n'//string2//char(0)
then the string '\r\n' will NOT be interpreted as an escape sequence, but as four characters, '\r\n'.
tropfen
to understand your reply correctly, i would like to create two examples.
Does it mean:
- when ever I use a fixed character string including \r\n or char(13)//char(10) end ending up with a final c it will work [e.g. 'Hello '//char(13)//char(10)//' world'//char(0)]
- when ever i use a composite character string like trim(string1)//char(13)//char(10) //trim(string2)//char(0) it will NOT work [i will have no new line but nice additional characters]
Thanks in advance
Frank
Jugoslav_Dujic
Quoting tropfen
Does it mean:
No. Both of your examples will work. As long as the CR+LF characters are there, and the string is char(0)-terminated, you'll be fine.
Basically, one should pick one style and stick with it. Since the "C-style" notation (\r\n) is non-standard, and only slightly shorter, I prefer always using char() and concatenation operator //. Of course, you can define a character(2), parameter:: CRLF=char(13)//char(10) and use that.
GVautier
New Contributor III
Hello
The example shown on the Microsoft reference page to MessageBox function http://msdn.microsoft.com/en-us/library/ms645505%28v=vs.85%29.aspx only mentions a \n to insert a newline :
[bash]int msgboxID = MessageBox(
        NULL,
        (LPCWSTR)L"Resource not availablenDo you want to try again?",
        (LPCWSTR)L"Account Details",
        MB_ICONWARNING | MB_CANCELTRYCONTINUE | MB_DEFBUTTON2
[/bash]
Robert_van_Amerongen
New Contributor III
In my MessageBox use I do only use ACHAR(13) to force a new line and that works fine. I do not seen any effect when I use ACHAR(10)//ACHAR(13)
Robert
In my experience, \n is sufficient.
New Contributor III
Steve,
you are correct. But because I prefer to have my source as much as possible conforming the Fortran standard I use in this case
"First line"//ACHAR(13)//"Second Line"//ACHAR(0)
in stead of
"First line\nSecond Line"C
although this will work as well!
Robert
You could use C_NEW_LINE and C_NULL from ISO_C_BINDING to be more portable. I was just pointing out that it is not necessary to also have the CR character in there.
New Contributor III
Steve,
Thanks for this idea!
Robert
