29647 Discussions
Minimum ifort version for E5-2670 processor?
kjkjkj
I'm wondering if recent processors require recent ifort versions? I'm currently using some code compiled on Xeon E5-2670 using ifort 11.1.075 and the performance is bad in some cases.
Now it may have nothing to do with the compiler - I thought it was worth asking though :).
Any takers?
thanks very much,
Kevin
"Require"? No. But you may not be taking best advantage of the CPU. With 11.1, try -xSSE4.2 . If you had the current compiler, you could use -xAVX for better code.
