Mixed Language Programming: C#, C++, and FORTRAN
Ibrahim_K_
Dear Friends;
I spend some time to develop an easy and consistent way to call C++/FORTRAN (DLL) from a Windows (WPF) main application which has its own console as well as a Windows GUI. The attached document describes the procedure I was able to use to achieve this. If there is any interest, I can post the source code or VS 2017 solution files as well.
i. konuk
JAlexiou
Just so I can understand you created a middle tier of C++/CLI such that you can add the Fortran code as a reference assembly instead of using `[DllImport()]` and hoping to get the arguments correct and not corrupt the stack. Kudos, this is really good work here.
Ibrahim_K_
Yes, indeed no DLLImport. All calls across the C# to C++/FORTRAN boundary are from Managed-To-Managed.
Yavuz_D_
İbrahim, Thanks for the attachment. Saved a lot for me.
Ibrahim_K_
Yavuz:
You are most welcome. Happy New Year!
i. konuk
