Module Scope Issue
nuclearlee
I have a really specific obscure bug I've found with getting some code to compile with both Intel Fortran (I'm using version 17.0.2.187 Build 20170213) and gfortran 6.2. I apologize in advance for my horrible overly long example code, it's simplified by quite a bit from the code from which the issue arose. In this example code, I have 3 modules: (1) A module "polymod" that defines a type "Thing"; (2) a module "testpolytype" that has a type "SimpleType" that has a type bound procedure that has a dummy argument of type "Thing"; (3) a module that has a function (TestUseWithTypeDef) that uses variables of type SimpleType and type Thing to call the type bound procedure in SimpleType.
*The attached code will not compile in gfortran (as I would expect, I get "Error: Derived type ‘thing’ at (1) is being used before it is defined"), if I don't explicitly "use polymod" (line 51) in the function "TestUseWithTypeDef", but compiles with intel fortran unless I specifically state "use testpolymod, only: SimpleType" (line 52). It seems to me that SimpleType should not come in to scope because it is used in a type bound procedure that is being called. Or am I misunderstanding some weird scoping issue with typebound procedures?*
module polymod
    implicit none
    interface Thing
        module procedure Initialize
    end interface Thing
    type :: Thing
        integer :: thingProp
    end type Thing
contains
    subroutine Initialize(this, thingProp)
        class(Thing) :: this
        integer, intent(in) :: thingProp
        this%thingProp = thingProp
    end subroutine Initialize
end module polymod
module testpolymod
    implicit none
    type SimpleType
    contains
        private
        procedure, public :: UseThing
    end type SimpleType
contains
    subroutine UseThing(this,dummyThing)
        use polymod
        class(SimpleType) :: this
        type(Thing), intent(inout) :: dummyThing
        dummyThing = Thing(42)
    end subroutine UseThing
end module testpolymod
module callermod
    implicit none
contains
    function TestUseWithTypeDef() result(intOut)
!        use polymod
        use  testpolymod
        integer :: intOut
        type(SimpleType) :: sT
        type(Thing) :: local_thing
        call sT%UseThing(local_thing)
        write(*,*)"thing prop: ", local_thing%thingProp
        intOut = local_thing%thingProp
    end function TestUseWithTypeDef
end module callermod
program testpoly
    use callermod
    implicit none
    write(*,*)TestUseWithTypeDef()
end program testpoly
Steve_Lionel
I agree with you - this should not compile. The specific issue is the reference to type thing in line 55. This is NOT a type exported by module testpolymod and hence is inaccessible in the function. I recall seeing similar issues of declarations "leaking" in similar circumstances.
Kevin_D_Intel
Thank you for reporting this defect and for the nice test case. I confirmed the findings and reported this to Development.
(Internal tracking id: DPD200419969)
