29649 Discussions
More problems with complex array parts
NCarlson
New Contributor II
I've encountered another problem involving complex array parts with ifx 2025.1. Here's an example:
type :: foo
  complex :: z(3)
end type
type(foo) :: a
call bar(a%z%re)
contains
  subroutine bar(x)
    real, intent(inout) :: x(:)
  end subroutine
end
The compiler gives this spurious error. The actual argument is very clearly neither a constant or expression.
$ ifx bug.f90
bug.f90(5): error #6638: An actual argument is an expression or constant; this is not valid since the associated dummy argument has the explicit INTENT(OUT) or INTENT(INOUT) attribute.
call bar(a%z%re)
compilation aborted for bug.f90 (code 1)
Trying to work around this via an ASSOCIATION block results in an ICE:
type :: foo
  complex :: z(3)
end type
type(foo) :: a
associate (z => a%z)
  call bar(z%re)
end associate
contains
  subroutine bar(x)
  end subroutine
end
$ ifx bug.f90
          #0 0x0000000003310581
          #1 0x0000000003375357
         #28 0x00007f74839d320b __libc_start_main + 139
         #29 0x000000000308f0ee
bug.f90(6): error #5623: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report.  Note: File and line given may not be explicit cause of this error.
  call bar(z%re)
compilation aborted for bug.f90 (code 3)
Another work around attempt using an ASSOCIATE block compiles without error, but produces invalid results.
type :: foo
  complex :: z(3)
end type
type(foo) :: a
a%z%re = -1
associate (z_re => a%z%re)
  call bar(z_re)
end associate
print *, a%z%re
if (any(a%z%re /= [1,2,3])) stop 'fail'
contains
  subroutine bar(x)
    x = [1,2,3]
  end subroutine
end
$ ifx bug.f90
$ ./a.out
  -1.000000      -1.000000      -1.000000
fail
The only workaround I've found that works is to manually do copy-in/copy-out of the complex array part to a real array temporary.
