29641 Discussions
Multiple symbol definition errors at link time
Todd_Peterson
I'm using Apple Xcode 2.4.1 and Intel Fortran v9.1.034 for Mac OS X running on a MacPro, OS: 10.4.8.
I am trying to link a dylib that contains a bunch of archive files of Fortran modules (compiled by me). I need to use the Apple "-all_load" linker flag to make sure all symbols from the Fortran archives get pulled into the dylib.
I also need to link in the Fortran runtime (libifcore.a), but when i do I also need to link in libimf.a and libirc.a. When I link in libirc.a, I get multiple symbol definition errors and I'm not sure what I need to do to fix this. Libirc.a is colliding with libgcc.a. Anyone offer any help? Thank you very much for any insight, I appreciate it.
Here is linker output and errors (I've put newlines in for readability):
g++ -o /src/cs_work2/macosx-i386/awlib/libawlib.dylib.1
-O0
-single_module
-all_load
/src/cs_work2/macosx-i386/lib/libawaxl.a
/src/cs_work2/macosx-i386/lib/libawbas.a
/src/cs_work2/macosx-i386/lib/libawdat.a
/src/cs_work2/macosx-i386/lib/libawmth.a
/src/cs_work2/macosx-i386/lib/libawss.a
/src/cs_work2/macosx-i386/lib/libawtsg.a
/src/cs_work2/macosx-i386/lib/libawutl.a
/src/cs_work2/macosx-i386/lib/libawxf.a
/src/cs_work2/macosx-i386/lib/libawxml.a
/src/cs_work2/macosx-i386/lib/libifcore.a
/src/cs_work2/macosx-i386/lib/libimf.a
/src/cs_work2/macosx-i386/lib/libirc.a
/src/cs_work2/macosx-i386/lib/libalval.a
-dynamiclib
-L/src/cs_work2/macosx-i386/lib
-L/src/licsdk/SDK/alval/MacOSX-i386
-L/Developer/SDKs/MacOSX10.4u.sdk/usr/lib
/src/cs_work2/macosx-i386/awlib/procntry.o
/src/cs_work2/macosx-i386/awlib/blckdata.o
/src/cs_work2/macosx-i386/awlib/tranblck.o
-ltempdir
-lplatdep
-lsvrdmgr
-ldatasrc
-laiocv
-lsvrdmgr
-lsvrerrs
-lreadonly
-lcvtrans
-ltmsutil
-lxerces-c
-lvizchart
-lxalan-c
-licuuc
-licudata
-licui18n
-lvserial
-lvutility
-lamsgs
-lademg
-lsfthread
-lxalanMsg
-lsockbsd
-lpthread
-ldl
-liconv
-llssrv
ld: multiple definitions of symbol ___muldi3
/src/cs_work2/macosx-i386/lib/libirc.a(mul64_gcc.o) definition of ___muldi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_muldi3.o) private external definition of ___muldi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___lshrdi3
/src/cs_work2/macosx-i386/lib/libirc.a(ushiftr64_gcc.o) definition of ___lshrdi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_lshrdi3.o) private external definition of ___lshrdi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___ashldi3
/src/cs_work2/macosx-i386/lib/libirc.a(shiftl64_gcc.o) definition of ___ashldi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_ashldi3.o) private external definition of ___ashldi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___ashrdi3
/src/cs_work2/macosx-i386/lib/libirc.a(shiftr64_gcc.o) definition of ___ashrdi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_ashrdi3.o) private external definition of ___ashrdi3 in section (__TEXT,__text)
ld: mult iple definitions of symbol ___divdi3
/src/cs_work2/macosx-i386/lib/libirc.a(udiv64_gcc.o) definition of ___divdi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_divdi3.o) private external definition of ___divdi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___moddi3
/src/cs_work2/macosx-i386/lib/libirc.a(urem64_gcc.o) definition of ___moddi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_moddi3.o) private external definition of ___moddi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___udivdi3
/src/cs_work2/macosx-i386/lib/libirc.a(udiv64_gcc.o) definition of ___udivdi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_udivdi3.o) private external definition of ___udivdi3 in section (__TEXT,__text)
ld: multiple definitions of symbol ___umoddi3
/src/cs_work2/macosx-i386/lib/libirc.a(urem64_gcc.o) definition of ___umoddi3 in section (__TEXT,__text)
/usr/lib/gcc/i686-apple-darwin8/4.0.1/libgcc.a(_umoddi3.o) private external definition of ___umoddi3 in section (__TEXT,__text)
ld: warning can't open dynamic library: @executable_path/../lib/libfmsgs.dylib.1 referenced from: /src/cs_work2/macosx-i386/lib/libsvrdmgr.dylib (checking for undefined symbols may be affected) (No such file or directory, errno = 2)
/Developer/SDKs/MacOSX10.4u.sdk/usr/lib/libgcc_s.10.4.dylib(_divdi3_s.o) definition of ___divdi3
/Developer/SDKs/MacOSX10.4u.sdk/usr/lib/libgcc_s.10.4.dylib(_udivdi3_s.o) definition of ___udivdi3
/Developer/SDKs/MacOSX10.4u.sdk/usr/lib/libgcc_s.10.4.dylib(_umoddi3_s.o) definition of ___umoddi3
/Developer/SDKs/MacOSX10.4u.sdk/usr/lib/libgcc_s.10.4.dylib(_moddi3_s.o) definition of ___moddi3
/usr/bin/libtool: internal link edit command failed
+ retcode=1
+ '[' 1 = 0 ']'
+ exit 1
make[1]: *** [libawlib.dylib] Error 1
make: *** [export] Error 2
Please report this problem to Intel Premier Support and it will be looked into. Thanks.
joseph-krahn
It might be possible to work around the problem by statically linking Intel libraries and dynamically linking the system libraries. It worked for me in Linux were there was a conflict with a newer gcc version. In Linux, the flag to do this is "-i-static" (but the flag is getting renamed in newer releases.)
Ron_Green
Two thoughts occur to me:
when compiling the Fortran, try the -cxxlib-gcc option. This will use c++ libs from gcc rather than Intel. I suspect this may remove the dependency on libirc. And use -i-static also as mentioned previously.
The other option - try using ifort as your linker instead of g++. But I suspect this will be much more complex. You could try to use ld explicitly. Again, this may be overkill.
ron
