The Sdrnd routine below is part of a much larger program. When the program is run for a particular set of input, which results in the Sdrnd input of X = 0, and N = 4, the result is 0 the first two times the function is called, but the third time and each time after that, the result is NaN.
I fixed a similiar problem with a NaN being produced elsewhere in the program instead of a very small number, by using the compile option /fp:precise for the project.
I can do a work-around by bypassing calculations for an input of zero, but am afraid that a similiar problem may exist elsewhere. Do you have any other suggestions.
I've added the build log for routine below.
Mike
FUNCTION Sdrnd( x, n )
! PURPOSE: Rounds X to N number of decimal places
! Examples: (49.9938,1) input rounds to 50.0
! (49.9938,2) input rounds to 49.99
! PARAMETERS IN CALL LIST
! NAME TYPE #DIM DESCRIPTION
! INPUT:
! x R*8 decimal number
! n I*4 number of decimal points after rounding
! OUTPUT:
! Sdrnd R*8 rounded decimal number
IMPLICIT NONE
INTEGER, PARAMETER :: dbl = SELECTED_REAL_KIND(14)
! List of calling arguments:
REAL(KIND=dbl), INTENT(IN) :: x
INTEGER, INTENT(IN) :: n
REAL(KIND=dbl) :: Sdrnd
! List of local variables:
REAL (KIND=dbl) :: y = 0.0
!*** Begin execution:
Sdrnd = 0.0
IF ( n == 0 ) y = 1.0d0
IF ( n == 1 ) y = 1.0d1
IF ( n == 2 ) y = 1.0d2
IF ( n == 3 ) y = 1.0d3
IF ( n == 4 ) y = 1.0d4
IF ( n == 5 ) y = 1.0d5
IF ( n == 6 ) y = 1.0d6
IF ( n == 7 ) y = 1.0d7
IF ( n == 8 ) y = 1.0d8
IF ( n == 9 ) y = 1.0d9
Sdrnd = ANINT( x * y ) / y
RETURN
END FUNCTION Sdrnd
Build Log
Build started: Project: CLASH_Fsrc, Configuration: Debug|Win32
Output
Compiling with Intel Visual Fortran 11.0.074 [IA-32]...
ifort /nologo /debug:full /Od /fp:precise /module:"Debug\\\\" /object:"Debug\\\\" /traceback /check:bounds
/libs:dll /threads /dbglibs /c /Qvc8
/Qlocation,link,"C:\\Program Files\\Microsoft Visual Studio 8\\VC\\bin" "D:\\ClearCase\\views\\cl_mwk_vs\\clash\\fsrc_f90\\Sdrnd.f90"
ifort: command line warning #10212: /fp:precise evaluates in source precision with Fortran.
CLASH_Fsrc - 0 error(s), 1 warning(s)
Apparently Random NaN results are often due to memory problems - are the arguments properly defined and initialized in your calling program? Are the arguments the same type in the calling program and subroutine.
David
The calling routine uses initialized variables of the correct type. There may be memory problems somewhere in the 110,000 lines of program Fortran code, or the 140,000 lines of C/C++ code, but this area is OK.
From other posts I've read, it appears that there is sometimes a problem when zero is divided by a number.
Mike
