Name conflict in Module
anishtain4
I have two subroutine in a module that both have one varibale, i. in one of them I want this be a integer and in another one this should be unite imaginary, but when I define it different types it says that this name has been defined in this file with another data type! I used another names to proceed my work but I would like to know how should I compensate with this?
another problem I have is that when I define functions after "end module" and want to call them into other functions or subroutines, visual studio recognize them as array and says they have not been defined! what should I do about this?
jimdempseyatthecove
Can you reduce the module and subroutines to a simple case that exhibits the symptions. Then post the code?
With this code at hand, we can then either see the problem or compile and experience the problem.
Jim
anishtain4
[bash]REAL(8) FUNCTION NDD_F(XI,F,X,n) !NEWTON DIVIDED DIFFERENCE_FORWARD
  IMPLICIT NONE
  REAL,INTENT(IN)	::XI(:),F(:),X
  INTEGER		::N
END FUNCTION
FUNCTION CONV(F,G,N)    !CONVOLUTION
  IMPLICIT NONE
  REAL,INTENT(IN)   ::F(N),G(N),N
END FUNCTION
SUBROUTINE FFT2(F,N)  !FFT FOR A POWER OF TWO
  F(I,:)= FS(B2D(RD2B(I,DECIMINATION)),:)
END SUBROUTINE
INTEGER FUNCTION RD2B(DEC,N)  !DECIMAL TO REVERSE BINARY
  IMPLICIT NONE
	INTEGER,INTENT(IN)	::DEC,N
	INTEGER							::I,DEC_D
	REAL								::EP
	RD2B		= 0
	DEC_D		= DEC
	EP			= 1E-5
	DO I=N,1,-1
		RD2B	= RD2B+MOD(DEC_D,2)*10**(I-1)
		DEC_D	= INT(DEC_D/2)
	END DO
END FUNCTION
INTEGER FUNCTION B2D(BIN) !BINARY TO DECIMAL
  IMPLICIT NONE
	INTEGER,INTENT(IN)	::BIN
	INTEGER							::I,N,BIN_D
	REAL								::EP
	B2D		= 0
	EP		= 1E-5
	BIN_D	= BIN
	N=INT(LOG10(EP+REAL(BIN_D)))+1
	DO I=1,N
		B2D = B2D+2**(I-1)*MOD(BIN_D,10**I)/10**(I-1)
	END DO
END FUNCTION[/bash]
In ndd_f I have defined N as an integer, but in conv I want to define N as a real (I know in this case that can be integer I may want to use this as wave number which is not always integer) and it says names conflict. These are all after "contains" in a module.
other problem is with the FFT2 and B2D and RD2B, when I put the later two functions after end module a syntax error appears in FFT which says they are not defined variables! I'm not sure if the pasted code helps you, but all of the code is a little bit long for here.
DavidWhite
Valued Contributor II
IMPLICIT NONE
END FUNCTION
The issue is not that you have the same name, but that you are trying to declare two arrays F and G with a real argument for the size. In the declarations for F(N) and G(N), the size of the arrays, "N" must be integer.
David
mecej4
You have to use integers for array dimensions, but you can do the following:
[fortran]REAL,INTENT(IN)   :: N, F(FLOOR(N)),G(FLOOR(N))
[/fortran]
anishtain4
Thanks david and mecej.
But one other question remained unanswered yet. if I wan to define a function after end module of a module file how should make fortran understand that it is a function not a variable?
Another question raised, is there anyway other than sending in N or using UBOUND() frequently to determine dimension of helping arrays in subroutine or functions?
To define a function we can write:
integer function test()
end function
or we can write:
function test()
integer::test(4)
end function
Is there any possibility that we use first form and define a function whos output is an array?
DavidWhite
You can define arrays which are passed as arguments as, e.g.
REAL,DIMENSION(*) :: X
X will take whatever size it is in the calling program.
My uderstanding on function returns is that you can only return a scalar (at least it was when I learned Fortran 30 years ago).
I would normally pass back arrays as arguments, and normally use subroutine calls:
Subroutine Test (XIN, XOUT)
REAL, DIMENSION(*), INTENT(IN) :: XIN
REAL, DIMENSION(*), INTENT(OUT) :: XOUT
This also avoids the need todefine fucntion type, as in your example.
David
You can now return arrays, but an explicit interface to the function must be visible to the caller.
