29487 Discussions
Need help for Fortran and C++ mixing
adaptiverotor
Hi:
I am switching from CVF to intel fortran for a project. The project was originally developed with CVF and VC6. now I want to use Visual studio 2005 and intel fortran9.1. I set Fortran project as main one and compile the c++ project as a static lib. Building C++ lib without problem. when I build fortran project, there are linking error LNK2019 happened. I am wondering what kind of changes I should make for this migrating? Thanks a lot!
Fortran code:
!====== Interfaces with C++ code ======!
INTERFACE
SUBROUTINE NetGenhelToC4ISR(initialize,YIn,P2CAux)
!DEC$ ATTRIBUTES C, ALIAS:'_Net_Genhel_to_C4ISR' :: NetGenhelToC4ISR
INTEGER*4 :: initialize
REAL*4 :: YIn(50)
REAL*4 :: P2CAux(20)
END SUBROUTINE
SUBROUTINE NetC4ISRToGenhel(initialize,YCmd,C2PAux)
!DEC$ ATTRIBUTES C, ALIAS:'_Net_C4ISR_to_Genhel' :: NetC4ISRToGenhel
REAL*4 :: YCmd(50)
REAL*4 :: C2PAux(20)
END SUBROUTINE
SUBROUTINE SetC4ISRIP(IPString,IPLength)
!DEC$ ATTRIBUTES C, ALIAS:'_SetC4ISRIP' :: SetC4ISRIP
CHARACTER*(*) IPString
INTEGER*4 :: IPLength
END SUBROUTINE
END INTERFACE
C++ code:
extern "C" { void SetC4ISRIP (char IPString[], int IPLength); }
void SetC4ISRIP(char IPString[], int IPLength) {
memset(C4ISRHostname,0,sizeof(C4ISRHostname));
memcpy(C4ISRHostname,IPString,IPLength);
C4ISRHostname[IPLength+1] = '\0';
// Net_Genhel_to_C4ISR (Genhel version) - sends data to Genhel
extern "C" { void Net_Genhel_to_C4ISR (int initialize,float YIn[50],float P2CAux[20]); }
void Net_Genhel_to_C4ISR(int initialize,float YIn[50],float P2CAux[20]) {
// Declare variables
bool C4ISROutConnected;
Genhel2C4ISR C4ISROut;
switch (initialize) {
case 1:
// Initialize network socket connection
wVersionRequestedC4ISR = MAKEWORD(2,2);
errC4ISR = WSAStartup(wVersionRequestedC4ISR,&wsaDataC4ISR);
hpC4ISR = gethostbyname(C4ISRHostname);
// If host is accessible
if (hpC4ISR != NULL) {
// Establish socket
// Clear address data structure
memset(&saC4ISR,0,sizeof(saC4ISR));
// Copy the address data from the host name lookup
memcpy((char *)&saC4ISR.sin_addr,hpC4ISR->h_addr,hpC4ISR->h_length);
// Set the address family (should be AF_INET)
saC4ISR.sin_family = hpC4ISR->h_addrtype;
// Set the port number (8002 for sending data from Genhel to C4ISR)
saC4ISR.sin_port = htons((u_short)8002);
// Create a datagram socket
C4ISROutSocket = socket(hpC4ISR->h_addrtype,SOCK_DGRAM,0);
// If socket is created
if (C4ISROutSocket >= 0) {
// Connect the socket (should always succeed for UDP)
if (connect(C4ISROutSocket,(struct sockaddr *)&saC4ISR,sizeof(saC4ISR)) < 0) {
// Socket did not connect
// Close socket
closesocket(C4ISROutSocket);
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error: Socket not connected\n");
else {
// Socket connected
// Set the socket to non-blocking mode
u_long arg = 1;
if (ioctlsocket(C4ISROutSocket,FIONBIO,&arg) == 0) {
C4ISROutConnected = TRUE;
else {
// Close socket
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error in setting socket to non-blocking mode\n");
else {
// Socket not created
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error: Socket not created\n");
else {
// Host not accessible
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error: Host not accessible\n");
// No break statement - continue on to send trim states
case 0:
case 2:
// Network communication
struct timeval tv;
fd_set reads,writes;
FD_ZERO(&writes);
FD_SET(C4ISROutSocket,&writes);
timeoutC4ISR = 0;
tv.tv_sec = timeoutC4ISR/1000;
tv.tv_usec = (timeoutC4ISR%1000)*1000;
// Define data to send from Genhel to the rotorcraft controller
for (idxC4ISR = 0; idxC4ISR < 50; idxC4ISR++) {
C4ISROut.YIn[idxC4ISR] = YIn[idxC4ISR];
for (idxC4ISR = 0; idxC4ISR < 20; idxC4ISR++) {
C4ISROut.P2CAux[idxC4ISR] = P2CAux[idxC4ISR];
lengthC4ISR = sizeof(C4ISROut);
select(FD_SETSIZE,&reads,&writes,0,&tv);
if (FD_ISSET(C4ISROutSocket,&writes)) {
// Send data to rotorcraft controller
errC4ISR = send(C4ISROutSocket,(const char *)&C4ISROut,lengthC4ISR,0);
else {
// Data not sent
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error: Data not sent\n");
if (initialize == 2) {
// End network communication
// Close socket
break;
default:
// Error
// Error message
fprintf(stderr,"Net_Genhel_to_C4ISR - Error in [initialize]\n");
break;
// Net_C4ISR_to_Genhel
extern "C" { void Net_C4ISR_to_Genhel (int initialize,float YCmd[50],float C2PAux[20]); }
void Net_C4ISR_to_Genhel(int initialize,float YCmd[50],float C2PAux[20]) {
bool C4ISRInConnected;
C4ISR2Genhel C4ISRIn;
case 1:
// Establish socket
saC4ISR.sin_addr.s_addr = INADDR_ANY;
saC4ISR.sin_family = AF_INET;
// Set the port number (8001 for sending data from C4ISR to Genhel)
saC4ISR.sin_port = htons((u_short)8001);
C4ISRInSocket = socket(AF_INET,SOCK_DGRAM,0);
if (C4ISRInSocket >= 0) {
u_long arg = 0;
if (ioctlsocket(C4ISRInSocket,FIONBIO,&arg) == 0) {
// Socket connected
C4ISRInConnected = TRUE;
else {
// Socket not connected
// Close socket
closesocket(C4ISRInSocket);
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Socket not connected\n");
if (bind(C4ISRInSocket,(struct sockaddr *)&saC4ISR,sizeof(saC4ISR)) != 0) {
// Close socket
C4ISRInConnected = FALSE;
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Socket not bound\n");
else {
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Socket not created\n");
else {
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Host not accessible\n");
// No break statement - continue on to receive initial data from rotorcraft controller
case 0:
struct timeval tv;
FD_ZERO(&reads);
FD_ZERO(&writes);
FD_SET(C4ISRInSocket,&reads);
timeoutC4ISR = 0;
lengthC4ISR = sizeof(C4ISRIn);
// Receive data from rotorcraft controller
errC4ISR = recv(C4ISRInSocket,(char *)&C4ISRIn,lengthC4ISR,0);
if (errC4ISR == lengthC4ISR) {
// Data received from rotorcraft controller
// Separate data out of data structure
YCmd[idxC4ISR] = float(C4ISRIn.YCmd[idxC4ISR]);
C2PAux[idxC4ISR] = float(C4ISRIn.C2PAux[idxC4ISR]);
else if (errC4ISR > 0) {
// Data received incorrectly
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Data received incorrectly\n");
else {
// Data not received
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error: Data not received\n");
break;
case 2:
// Close socket
break;
default:
// Error
// Error message
fprintf(stderr,"Net_C4ISR_to_Genhel - Error in [initialize]\n");
break;
See this Knowledge Base article. If you are using VS2005, make sure it has SP1 applied.
adaptiverotor
Thanks Steve. I do have SP1 installed. I read the article and my case is different. I use Fortran project as main program. and intel fortran compiler 9.1. Is there a similar article for my situation?
Wei
adaptiverotor
also, the error messages are:
1>C4ISR.obj : error LNK2019: unresolved external symbol _Net_Genhel_to_C4ISR referenced in function _C4ISR
1>C4ISR.obj : error LNK2019: unresolved external symbol _SetC4ISRIP referenced in function _C4ISR
1>C4ISR.obj : error LNK2019: unresolved external symbol _Net_C4ISR_to_Genhel referenced in function _C4ISR
Is this a 32-bit or 64-bit platform? Did you make the C++ library project a "dependent" of the Fortran main project?
I have seen, sometimes, that even if the library project is set as a dependent that the linker is not asked to link in the library. In that case you can add the .lib output from the library project as a "source" for the main.
adaptiverotor
Though the cpu is athlon 64x2, the OS is windows XP PRO. I think this should be 32-bit platform. The compiler I use is IA32. Am I right?
Yes, that's right. Look in the buildlog.htm file in the Debug or Release subfolder at the command generated for the link step. Does it include the name of your C++ library?
