29278 Discussions
Non-deterministic results from ARPACK
greg_rowe
I've compiled ARPACK using visual fortran and I get slightly different values each time it is run. This could be a slight change in magnitude or a change in sign of eigenvectors. Could this be due to not aligning double arrays to 16 byte boundaries (if so how would I do this)? Please help.
TimP
Quoting - greg.rowe
If the differences are due to alignments on 32-bit Windows, you may be able to avoid it by setting /fp:source (on a compiler recent enough to support that switch). If your source is entirely Fortran, about the only obvious control you have over alignment of double precision arrays is to make sure they aren't preceded by data typesother than double complex in COMMON blocks or derived types. Since ifort 8.1, local data should be aligned automatically.
