Not using FMA?
rudi-gaelzer
Using:
Intel(R) Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.3.210 Build 20160415
Processor: Intel(R) Core(TM) i7-4960X
Fedora Linux 24
According to Intel's specifications for this processor in:
http://ark.intel.com/products/77779/Intel-Core-i7-4960X-Processor-Extreme-Edition-15M-Cache-up-to-4_00-GHz
it suports Instruction Set Extensions SSE4.2, AVX, AES
Hence, according to the Intel® Fortran Compiler 16.0 User and Reference Guide, if I compile with "-fma" and "-march=core-avx2" or "-xHost" the compiler should create code with fused multiply-add (FMA) instructions.
I decided to test if this is the case for me.  I've found a simple test program in:
https://www.pgroup.com/lit/articles/insider/v3n3a4.htm
which I adapted as
program testfma3
implicit none
double precision :: a, b, c, d
!a = Z'3c54c9b71a0e6500'       !  4.507E-018
a = z'bF1A28A5F3777D60'
b = Z'bf43a04556d864ae'       ! -5.989E-004
c = Z'bfc55364b6b08299'       ! -0.166
d = 0.0d0
d= a + b*c
write(6,100) "Result: ",d,"(",d,")"
100 format (" ",a15,Z,a1,e22.16,a1)
end program testfma3
I compiled the code with
ifort -march=core-avx2 -fma testfma3.f90 -o testfma3x
and
ifort -xHost -fma testfma3.f90 -o testfma3x
In both cases I got the result:
Result:                       0(0.0000000000000000E+00)
when, according to the test, I should have obtained
BBBAD89127ADE008(-.5684854190555145E-20)
Does it mean that my processor does not generate FMA instructions after all?
TimP
As your CPU supports AVX, but not AVX2, there is no FMA.
You might check to see whether your floating point expressions are evaluated at compile time, particularly as it seems the compiler didn't try to generate an AVX2 instruction when so requested.
Also, it appears that 0.0 may be the expected result, FMA or not.
rudi-gaelzer
Oh, OK.  Thanks.
Was the AVX2 instruction set implemented only from generation 5 processors?
How exactly do I "check to see whether your floating point expressions are evaluated at compile time"?
TimP
When I set -S option to generate asm code, it appears that the result was evaluted at compile time, as there are no floating point instructions.
rudi-gaelzer
Not according to the text I cited.  But I cannot verify, as I don't have access to FMA...
TimP
The paper you referred to quoted 0.0 as the expected result without FMA, with rounding mode set to "up."  As you didn't set rounding mode, it is required to default to "nearest."  I don't know whether there any set requirements on rounding mode and precision for compile-time evaluation.
