29284 Discussions
ODEPACK Solutions debugging on intel fortran 77 on Visual Studio 2012
Aravind_R_
I am trying to compile a set of source codes of the ODEPACK ODE solvers, but I am getting errors indicating aliasing issues. Please let me know what you think of the following:
When the overall source codes are run, this is the result:
Error    1          error #6633: The type of the actual argument differs from the type of the dummy argument.   [RWORK]            C:\Users\FortranCompiler\Desktop\Liu text files\opkdmain.f            3445
Error    2          Compilation Aborted (code 1)            C:\Users\FortranCompiler\Desktop\Liu text files\opkdmain.f            1
Error    3          error #6633: The type of the actual argument differs from the type of the dummy argument.   [RWORK]            C:\Users\FortranCompiler\Desktop\Liu text files\opkda1.f  9499
Error    4          Compilation Aborted (code 1)            C:\Users\FortranCompiler\Desktop\Liu text files\opkda1.f  1
List of files and areas of code error:
opkdmain.f
C-----------------------------------------------------------------------
C    CALL DSTODE(NEQ,Y,YH,NYH,YH,EWT,SAVF,ACOR,WM,WM,F,JAC,DPRJS,DSOLSS)
      CALL DSTODE (NEQ, Y,RWORK(LYH), NYH,RWORK(LYH),RWORK(LEWT),
     1   RWORK(LSAVF),RWORK(LACOR),RWORK(LWM),RWORK(LWM),
     2   F, JAC, DPRJS, DSOLSS)
      KGO = 1 - KFLAG
      GO TO (300, 530, 540, 550), KGO
opkda1.f :
C Call DPREPI to do matrix preprocessing operations. -------------------
      CALL DPREPI (NEQ, Y, S, RWORK(LYH), RWORK(LSAVF),
     1   RWORK(LEWT),RWORK(LACOR),IA,JA,IC,JC,RWORK(LWM),
     2   RWORK(LWM), IPFLAG,RES, JAC, ADDA)
      LENWK = MAX(LREQ,LWMIN)
      IF (IPFLAG .LT. 0) RETURN
C If DPREPI was successful, move YH to end of required space for WM. ---
      LYHN = LWM + LENWK
      IF (LYHN .GT. LYH) RETURN
      LYHD = LYH - LYHN
      IF (LYHD .EQ. 0) GO TO 20
      IMAX = LYHN - 1 + LENYHM
      DO 10 I=LYHN,IMAX
 10     RWORK(I) = RWORK(I+LYHD)
      LYH = LYHN
C Reset pointers for SAVR, EWT, and ACOR. ------------------------------
 20   LSAVF = LYH + LENYH
      LEWTN = LSAVF + N
      LACOR = LEWTN + N
      IF (ISTATC .EQ. 3) GO TO 40
C If ISTATE = 1, move EWT (left) to its new position. ------------------
      IF (LEWTN .GT. LEWT) RETURN
      DO 30 I=1,N
 30     RWORK(I+LEWTN-1) = RWORK(I+LEWT-1)
 40   LEWT = LEWTN
      RETURN
C----------------------- End of Subroutine DIPREPI ---------------------
      END
*DECK DPREPI
      SUBROUTINE DPREPI (NEQ, Y, S,YH,SAVR,EWT,RTEM,IA,JA,IC,JC,
     1                   WK, IWK, IPPER, RES, JAC, ADDA)
      EXTERNAL RES, JAC, ADDA
      INTEGER NEQ, IA, JA, IC, JC, IWK, IPPER
      DOUBLE PRECISION Y, S, YH, SAVR, EWT, RTEM, WK
      DIMENSION NEQ(*), Y(*), S(*), YH(*), SAVR(*), EWT(*), RTEM(*),
     1   IA(*), JA(*), IC(*), JC(*), WK(*), IWK(*)
      INTEGER IOWND, IOWNS,
     1   ICF, IERPJ, IERSL, JCUR, JSTART, KFLAG, L,
     2   LYH, LEWT, LACOR, LSAVF, LWM, LIWM, METH, MITER,
     3   MAXORD, MAXCOR, MSBP, MXNCF, N, NQ, NST, NFE, NJE, NQU
      INTEGER IPLOST, IESP, ISTATC, IYS, IBA, IBIAN, IBJAN, IBJGP,
     1   IPIAN, IPJAN, IPJGP, IPIGP, IPR, IPC, IPIC, IPISP, IPRSP, IPA,
     2   LENYH, LENYHM, LENWK, LREQ, LRAT, LREST, LWMIN, MOSS, MSBJ,
     3   NSLJ, NGP, NLU, NNZ, NSP, NZL, NZU
      DOUBLE PRECISION ROWNS,
     1   CCMAX, EL0, H, HMIN, HMXI, HU, RC, TN, UROUND
      DOUBLE PRECISION RLSS
Analysis: Both files have same error with  the way RWORK is classified. From the originally run program, RWORK is classified as follows:
  EXTERNAL FEX, JAC
      DOUBLE PRECISION ATOL, RTOL, RWORK, T, TOUT, Y
      DIMENSION NEQ(12),Y(12), RWORK(500), IWORK(30), RTOL(12), ATOL(12)
      DATA LRW/500/, LIW/30/
      NEQ(1) = 12
      DO 10 I = 1,NEQ(1)
 10    Y(I) = 0.0D0
       Y(1) = 1.0D0
       T = 0.0D0
       TOUT = 0.1D0
       ITOL = 1
       RTOL = 1.0D-4
       ATOL = 1.0D-6
       ITASK = 1
       QISTATE = 1
       IOPT = 0
       MF = 121
      DO 40 IOUT = 1,5
       CALL DLSODES (FEX, NEQ, Y, T, TOUT, ITOL, RTOL, ATOL,
     1     ITASK, ISTATE, IOPT, RWORK, LRW, IWORK, LIW, JAC, MF)
As listed in the opkdmain.f file of odepack subroutines:
C RWORK  = a work array used for a mixture of real (double precision)
C          and integer work space.
C          The length of RWORK (in real words) must be at least
C             20 + NYH*(MAXORD + 1) + 3*NEQ + LWM    where
C          NYH    = the initial value of NEQ,
C          MAXORD = 12 (if METH = 1) or 5 (if METH = 2) (unless a
C                   smaller value is given as an optional input),
C          LWM = 0                                    if MITER = 0,
C          LWM = 2*NNZ + 2*NEQ + (NNZ+9*NEQ)/LENRAT   if MITER = 1,
C          LWM = 2*NNZ + 2*NEQ + (NNZ+10*NEQ)/LENRAT  if MITER = 2,
C          LWM = NEQ + 2                              if MITER = 3.
C          In the above formulas,
C          NNZ    = number of nonzero elements in the Jacobian matrix.
C          LENRAT = the real to integer wordlength ratio (usually 1 in
C                   single precision and 2 in double precision).
C          (See the MF description for METH and MITER.)
C          Thus if MAXORD has its default value and NEQ is constant,
C          the minimum length of RWORK is:
C             20 + 16*NEQ        for MF = 10,
C             20 + 16*NEQ + LWM  for MF = 11, 111, 211, 12, 112, 212,
C             22 + 17*NEQ        for MF = 13,
C             20 +  9*NEQ        for MF = 20,
C             20 +  9*NEQ + LWM  for MF = 21, 121, 221, 22, 122, 222,
C             22 + 10*NEQ        for MF = 23.
C          If MITER = 1 or 2, the above formula for LWM is only a
C          crude lower bound.  The required length of RWORK cannot
C          be readily predicted in general, as it depends on the
C          sparsity structure of the problem.  Some experimentation
C          may be necessary.
C
C          The first 20 words of RWORK are reserved for conditional
C          and optional inputs and optional outputs.
C
C          The following word in RWORK is a conditional input:
C            RWORK(1) = TCRIT = critical value of t which the solver
C                       is not to overshoot.  Required if ITASK is
C                       4 or 5, and ignored otherwise.  (See ITASK.)
C
C LRW    = the length of the array RWORK, as declared by the user.
C          (This will be checked by the solver.)
C
C IWORK  = an integer work array.  The length of IWORK must be at least
C             31 + NEQ + NNZ   if MOSS = 0 and MITER = 1 or 2, or
C             30               otherwise.
C          (NNZ is the number of nonzero elements in df/dy.)
C
C          In DLSODES, IWORK is used only for conditional and
C          optional inputs and optional outputs.
C
C          The following two blocks of words in IWORK are conditional
C          inputs, required if MOSS = 0 and MITER = 1 or 2, but not
C          otherwise (see the description of MF for MOSS).
C            IWORK(30+j) = IA(j)     (j=1,...,NEQ+1)
C            IWORK(31+NEQ+k) = JA(k) (k=1,...,NNZ)
C          The two arrays IA and JA describe the sparsity structure
C          to be assumed for the Jacobian matrix.  JA contains the row
C          indices where nonzero elements occur, reading in columnwise
C          order, and IA contains the starting locations in JA of the
C          descriptions of columns 1,...,NEQ, in that order, with
C          IA(1) = 1.  Thus, for each column index j = 1,...,NEQ, the
C          values of the row index i in column j where a nonzero
C          element may occur are given by
C            i = JA(k),  where   IA(j) .le. k .lt. IA(j+1).
C          If NNZ is the total number of nonzero locations assumed,
C          then the length of the JA array is NNZ, and IA(NEQ+1) must
C          be NNZ + 1.  Duplicate entries are not allowed.
It seems that the sections that RWORK is taken as an array of a mix of double precision and integer data types. Is it possible for the RWORK array to contain two different data types or must it only contain one based on Intel's aliasing rules for Fortran 77. Please let me  know if the structure of the code right now is in error or if there is an alternative way of allowing RWORK to include both INTEGER and DOUBLE PRECISION data types.
Thank you!
