We have installed Intel compilers v11.0.061 and try to recompile our program correctly worked with v10 compilers. Using 64-bit compiler the code is still correctly compiled, while using 32-bit compilation (both Debug and Release) we see the message:
catastrophic error: **Internal compiler error: internal abort** Please report this error along with the circumstances in which it occurred in a Software Problem Report. Note: File and line given may not be explicit cause of this error.
in file Source.f90, line 323, column 7. At this line there is only !$OMP PARALLEL directive.
Could you please suggest us any workaround about this topic?
If you can attach a short but complete sample that shows the problem, do so here. Otherwise, open an issue with Intel Premier Support.
EM:
This is bug in the new version 11. It is related to the use of the option: /iface:cvf. See my post and Steve's answers.
Reinaldo
It may not be the same error. Please provide a test case.
