29429 Discussions
OMP: Warning #2: Cannot open message catalog 1053libiompui.dll
Henrik2
After installing IVF 11.1.054 (previous version was 11.1.0.51) I get the following error when the program is executed (I am using OpenMP).
OMP: Warning #2: Cannot open message catalog 1053\libiomp5ui.dll
OMP: System error #126: a message in Swedish. Translation: The module can not be found
OMP: Info #3: Default message will be used.
I do not have the folder 1053 under the IVF compiler folder. But I have a folder named 1041 with thelibiomp5ui.dll file
It did not help to deinstall the previous version of IVF.
I also see that the help on IVF 11.1.054 does not seem work after deinstalling version 11.1.0.51.
I am using a Swedish version of Windows Vista 64bit.
Henrik
Thanks - we're aware of the OMP warning and are working on a fix. If you want to go back to 051, uninstall Update 4, reinstall Update 3 ans make sure the PATH environment variable points to the 051 LIB folder.
Henrik2
Ok,
I am now using 051 again.
Henrik
barragan_villanueva_
Valued Contributor I
You can suppress warnings by setting in environment:
KMP_AFFINITY=nowarnings
Let me know if it works for you
This should be fixed in 11.1 Update 6, available now.
