OOP related bug in ifx
GreenScreen
The following code is a minimal reproducer of a bug in ifx's (and ifort's) support of Fortran's OOP features that has been bugging me for ages. This test code should simply execute, and exit gracefully (and it does indeed so using LLVM's Flang compiler, version 19.0.0).
module base_module
   type, abstract :: BaseType
   contains
      procedure(method), deferred  :: method
   end type BaseType
   abstract interface
      subroutine method(self)
         import
         class(BaseType), intent(in) :: self
      end subroutine method
   end interface
end module base_module
module ext_module
   use base_module, only: BaseType
   type, extends(BaseType) :: ExtType
      real(8), allocatable :: y(:,:)
   contains
      procedure :: method
   end type ExtType
contains
      class(ExtType), intent(in) :: self
      y = self%y
end module ext_module
program main
   use ext_module,  only: ExtType
   class(BaseType), allocatable :: arr(:)
   arr = make_arr()
   call arr(1)%method()
contains
   function make_arr() result(arr)
      real :: y(32768,2)
      allocate(ExtType :: arr(1))
      arr = ExtType(y)
   end function make_arr
end program main
When compiled and run with ifx (Version 2025.0.4 Build 20241205), the result is a segmentation fault, with the following trace-back:
forrtl: severe (174): SIGSEGV, segmentation fault occurred
Image              PC                Routine            Line        Source
libc.so.6          0000152670033520  Unknown               Unknown  Unknown
main.ifx           00000000004655E0  __intel_ssse3_mem     Unknown  Unknown
main.ifx           000000000040547E  Unknown               Unknown  Unknown
main.ifx           0000000000405A56  Unknown               Unknown  Unknown
main.ifx           000000000040516D  Unknown               Unknown  Unknown
libc.so.6          000015267001AD90  Unknown               Unknown  Unknown
libc.so.6          000015267001AE40  __libc_start_main     Unknown  Unknown
main.ifx           0000000000405085  Unknown               Unknown  Unknown
The problem seems to be somehow connected to the fact that the procedure make_arr is coded as a function. When this procedure is transformed into a subroutine, the segfault vanishes.
TobiasK
@GreenScreen
Can you give more details on how you compile the code? On Linux with -O0 I don't see an issue.
GreenScreen
ifx main.f90 -o main.ifx
I am using ifx Version 2025.0.4 Build 20241205 on Linux Mint 21.1 Vera.
GreenScreen
I've tried the -O0 option for compilation, but it doesn't change anything. It still segfaults.
(Always assuming that the code that I've posted above is stored in a single file, main.f90.)
TobiasK
Ok, while playing around with the code I changed the second dimension of y to 1 which triggers the segfault only if -heap-arrays are used.
With your original size it fails regardless of heap-arrays.
I escalated it to our developers.
GreenScreen
