Hi, I compiled a openmp program with intel fortran successfully, and this is my macros and Makefile:
macros
1 .IGNORE:
2 RM = rm -f
3 COMPILER90= ifort -openmp #-fbounds-check
4 FREESOURCE= -free #-ffree-form
5 F90FLAGS = -c -I/home/2015051066/soft/netcdf/include
6 MODFLAG =
7 LDFLAGS = -O3
8 CPP = cpp
9 CPPFLAGS = -P -traditional
10 #F90FLAGS = -c -I/cm/shared/apps/netcdf/gcc/64/4.5.0/include
11 #F90FLAGS = -c -I/cm/shared/uaapps/netcdf/fortran/gcc/4.4.4/include
12 #F90FLAGS = -c -I/home/u4/niug/netcdf-fort-4.4.4/include
13 RM = rm -f
14 RM = rm -f
15 RM = rm -f
16 RM = rm -f
17 RM = rm -f
Makefile
1 # Makefile
2 #
3 #INCLUDES=
4 .SUFFIXES:
5 .SUFFIXES: .o .f
6
7 include ../macros
8
9 MAINOBJ1 = ../IO_code/Noah_driver.o
10
11 OBJS = \
12 ../Noah_code/module_Noahlsm.o \
13 ../Noah_code/module_Noahlsm_param_init.o \
14 ../Noah_code/module_Noahlsm_utility.o \
15 ../Noah_code/module_date_utilities.o \
16 ../IO_code/module_Noah_NC_output.o \
17 ../IO_code/module_Noahlsm_gridded_input.o
18
19 CMD = Noah
20 all: $(CMD)
21
22 Noah: $(OBJS) $(MAINOBJ1)
23 @echo ""
24 $(COMPILER90) -o $(@) $(OBJS) $(MAINOBJ1) -L/home/2015051066/soft/netcdf/lib -lnetcdff -lnetcdf
25 # $(COMPILER90) -o $(@) $(OBJS) $(MAINOBJ1) -L/cm/shared/apps/netcdf/gcc/64/4.5.0/lib -lnetcdff -lnetcdf
26 # $(COMPILER90) -o $(@) $(OBJS) $(MAINOBJ1) -L/cm/shared/uaapps/netcdf/fortran/gcc/4.4.4/lib -lnetcdff -lnetcdf
27 @echo ""
28
29 # This command cleans up
30
31 clean:
32 rm ../IO_code/*mod ../IO_code/*.o
33 rm ../Noah_code/*mod ../Noah_code/*.o
34 rm $(CMD)
When I run the model with the pbs script:
1 #!/bin/sh -f
2 #PBS -N test
3 #PBS -m n
4 #PBS -l mem=1gb
5 #PBS -l nodes=1:ppn=28
6 nprocs=`wc -l < $PBS_NODEFILE`
7 cd $PBS_O_WORKDIR
8 #date
9 #mpirun -genv I_MPI_DEVICE ssm -np $nprocs -hostfile $PBS_NODEFILE $PBS_O_WORKDIR/test.sh
10 #cd /home/2014011989/noahmp/Run
11 /usr/bin/time ./Noah >&out
12 #date
13
The error is:
1 mdt, minute = 01010000
2 INPUT LANDUSE = USGS
3 LANDUSE TYPE = USGS FOUND 27 CATEGORIES
4 INPUT SOIL TEXTURE CLASSIFICAION = STAS
5 SOIL TEXTURE CLASSIFICATION = STAS FOUND 19 CATEGORIES
6 successful initialize general model parameters
7 ------------- successful reading surface data ------------------
8 30
9 0.3950000 0.4100000 0.4340000 0.4760000 0.4850000
10 0.4390000 0.4040000 0.4640000 0.4650000 0.4060000
11 0.4680000 0.4680000 0.3950000 1.000000 0.2000000
12 0.4210000 0.4680000 0.2000000 0.3390000 0.0000000E+00
13 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
14 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00 0.0000000E+00
15 fini=arbitrary initialization
16 ------------- successful initialization ------------------
17 1 1980 1 1 1 0 1
18 -------------------------------------------
19 READFORC: opening /home/2014011989/noahmp/Noah_data/forcings/1980/1980010100.nc
20 The model is losing(-)/gaining(+) fake water
21 ERRWAT = -5.000397
22 ix,iy,WA,END_WB,BEG_WB,PRCP*DT,ECAN*DT,EDIR*DT,ETRAN*DT,RUNSRF*DT,RUNSUB*DT
23 The model is losing(-)/gaining(+) fake water
24 forrtl: severe (40): recursive I/O operation, unit -1, file unknown
25 �^H~[^@^@^@^@^@~@Y~W^@^@^@^@^@^@^@^@^@^@^@^@^@^@4.02user 2.11system 0:13.07elapsed 46%CPU (0avgtext+0avgdata 150056maxresiden t)k
26 22032inputs+0outputs (0major+51064minor)pagefaults 0swaps
Is the problem from my wrong script? How to solve it?
Thank you very much!
- « Previous
- 1
- 2
- Next »
Thanks for all help!
- « Previous
- 1
- 2
- Next »
