29389 Discussions
Object-bound procedures in Fortran 2003
n_kirkbysurrey_ac_uk
Are object-bound procedures available yet for both functions and subroutines? With an abstract interface that clearly states a subroutine is to be the target, the compiler complains when I try to assign the component to a subroutine, stating that it was expecting a function.
I have got type-bound procedures working fine.
Norman
Andrew_Smith
Valued Contributor I
I never heard of an object bound procedure. Could you post some code?
Wendy_Doerner__Intel
Also could you post a reference to it from the relevantFortran standard?
Wendy
Attaching or including files in a post
reinhold-bader
New Contributor II
"object-bound" procedure to my knowledge is an alternative term for "procedure pointer type component". These indeed should be supported in 11.1 (although some bugs may still be outstanding). A code example would indeed be required to see what is going on.
Reinhold
