QWINFO is defined in ifqwin.90 as a structure.If you pretend it's a defined type, it works, but you get a complaint about using %. as the separator. The way I now have it coded is shown below, but the record statement gets flagged as not allowed by f2003:
"Fortran 2003 does not allow this statement or directive."
RECORD /qwinfo/ qwiinteger(4) i
! Set window frame size.
qwi.x = 0
qwi.y = 0
qwi.w = 0
qwi.h = 0
qwi.type = QWIN$SET
Will ifqwin.90 and other includes ever be brought up to the f2003 standard?
Someone got a bit too carried away here regarding the warning about use of % and not allowing the use of QWINFO in a TYPE statement. We'll look into that.
Some of the structures cannot be represented as standard derived types, especially those with unions. However, this should not matter,
