29427 Discussions
OpenMP- No problem with parallel studio 2013(on windows).But Segmentation fault if parallel studio 2011.
britz0907
Hello.
I tried to generate scientific OpenMP based parallel code using previous serial code.
With parallel studio 2013+visual studio 2012, I've made successful parallel code.
However, generated code ouccurs segemation fault on linux version(parallel studio 2011).
-> forrtl: severe (174): SIGSEGV, segmentation fault occurred
I made serveral variable(type: integer, real) as a firstprivate.
Parallel studio 2013+visual studio 2012 has correct value, but parallel studio 2011 generates trash value.
jimdempseyatthecove
SIGSEGV is usually an indication of too small of stack (too much on specified/implicit stack). Check what conditions affect the stack capacity and either adjust them or reduce stack requirements (e.g. enable heap arrays, or explicitly allocate large arrays).
Jim Dempsey
TimP
Both your shell stack limit and the thread stack size (OMP_STACKSIZE) may need attention if you can't solve by -heap-arrays.
ulimit -s unlimited (if using an sh style shell) plays a role analogous to the stack size you would set in a Windows .exe.
private arrays may greatly increase both stack sizes.
britz0907
Thanks Jim & TimP.
Unfortunately, I've already complied using -heap-arrays tag, and checked stack size.
However, the problem is not resolved with SIGSEGV & Stack trace terminated abnormally errors.
Even if a stack size is no need adjustment(small size problem),
Surprisingly, the program,which built by parallel studio 2011 on windows, occurs same problem.
My command lines of visual studio 2012 to bulid codes using parallel studio is
/nologo /debug:full /O1 /Qopenmp /real_size:64 /module:"Debug\\" /object:"Debug\\" /Fd"Debug\vc110.pdb" /libs:static /threads /dbglibs /Qmkl:sequential /c
(The compile option is same both parallel studio 2011 and parallel studio 2013.)
(Errors are not occured during complie time, but 2013-> well & 2011-> not)
britz0907
My ifort version
ifort version 12.1.5 - linux
parallel studio 2013 update 1 - windows
parallel studio 2011 update 10 - windows
jimdempseyatthecove
What happens when you compile with OpenMP and stubs?
What happens when you compile with OpenMP (normal parallel code) and add in PROGRAM as the first parallel region:
!$OMP PARALLEL
WRITE(*,*) omp_get_thread_num()
!$OMP END PARALLEL
The above is a low stack consuming parallel region. If this runs, then suspect a resource (low stack) or coding issue (e.g. uninitialized variable). Have you compiled with gen-interfaces/warn-interfaces and full runtime checks?
Jim Dempsey
britz0907
Jim.
!$OMP PARALLEL
!$OMP END PARALLEL
The above region is no problem on my codes.
I believe that this problem may be related with uninitialized variable
because the codes run on very small size problem without errors.
As I mentioned, I've checked trash values( uninitialized values) occurs this problem.
I shall confirm some uninitialized values using your recommended compile tags.
TimP
It has been difficult to use the combination -check uninit -openmp.  It's good practice to have the build set up so as to be able to run without -openmp and run checks for uninitialized data.  More comprehensive advice on finding undefined data:
http://www.nas.nasa.gov/hecc/assets/pdf/training/UnInit_Fix_your_code_2012_10_31.pdf
Note that official Fortran terminology (undefined) differs from Intel's uninitialized, which applies also to icpc.
jimdempseyatthecove
This reminds me that one should check to see if one is using PRIVATE(X) is used when FIRSTPRIVATE(X) is intended (required) to be used.
Jim Dempsey
