Dear Intel Community,
I think I discovered a bug causing insufficient virtual memory when trying to allocate arrays.
Setup VS 2017 Community and Intel Fortran Compiler 17.0.2.187 and 17.0.4.210 (32-bit and 64-bit), with VS 2013 Ultimate the same problem occurs.
The following minimalistic example already fails to run, when using Compiler flags:
/Qopenmp_stubs /libs:qwins /dbglibs
linker flags:
/SUBSYSTEM:WINDOWS and /SUBSYSTEM:CONSOLE
Example works with /Qopenmp or Intel Fortran Compiler 15.0.6.285 (with the above given flags)
program Console2 implicit none real*8, allocatable :: testArr(:) allocate(testArr(1)) end program Console2
Did I do something wrong or is there a bug?
Kind regards,
Simon Klarmann
I have reproduced the error and opened a bug report for it. The track bug ID is CMPLRS-43555.
Xiaoping Duan
Intel Customer Support
We are having this problem as well. How can we follow the status of this bug?
