Hi there-,
I was directed to this forum last week from the "Threading on Intel® Parallel Architectures " forum. My question is regarding the initialization of private variables used by the OpenMP REDUCTION clause. If array a is initialized to 1, I assume that private copies spawned for each thread following the REDUCTION(+:a) clause, are also initialized to 1. Consider the following trivial code
! Initialize
a(1,1:10)=1.0d0
a(2,1:5)=1.0d0
a(2,6:10)=2.0d0
!$ nthreads=1
!$ call omp_set_num_threads(nthreads)
!$ omp parallel do private(i) reduction(+:a)
do i=1, 10
a(2,i)=a(2,i)+a(1,i)
end do
!$ omp end parallel do
If I compile without the -openmp flag using Intel Fortran v11.1 on a 64-bit Linux machine, I obtain the correct or expected results, a(2,1:5)=2.0d0 and a(2,6:10)=3.0d0. However, if I compile with the -openmp flag and run the program, I obtain a(2,1:5)=1.0d0 and a(2,6:10)=2.0d0, because a(1,1:10)=0.0d0 (I checked this by simply adding a print statement). Perhaps there is something wrong with code post above?
A second question I posted in the other forum was regarding a reduction on part of the shared array a. Let's assume I take the same code as shown above and assume it is working correctly (the private copies of a are initialized to the right value). If I change the extent of the loop from do i=1, 10 to do i=1, 5, will the reduction be performed over all the elements or only the elements of the array that were changed inside the loop? That is, will the reduction yield a(2,1:10)=2.0d0 or a(2,1:5)=2.0d0 and a(2,6:10)=4.0d0.
Please feel free to comment. Any help is greatly appreciated.
