29640 Discussions
OpenMP Task Dependency with ifort 15
Martin_K_7
I am currently trying to use the *task* construct of OpenMP 4.0 including the *depend* statement for my Fortran codes. Therefore, I create the following example, which should fill up the first row of a matrix with the numbers 1 to M by a task and fill up the remaining elements by a task each whenever the element in the first row is ready. This results in the following piece of code:
     PROGRAM OMP_TEST
        IMPLICIT NONE
        INTEGER K,L
        INTEGER M
        PARAMETER (M = 8)
        INTEGER A(M,M)
        A(1:M, 1:M) = 0
        !$omp parallel
        !$omp single
        DO L=1, M
            !$omp task depend(out:A(1,L)) default(shared)
            A(1,L) = L
            !$omp end task
            DO K = 2, M
                !$omp task depend(in:A(1,L)) default(shared)
                A(K,L) = A(1,L)
                !$omp end task
            END DO
        END DO
        !$omp taskwait
        !$omp end single
        !$omp end parallel
        DO K =1 , M
            WRITE(*,*) A(K,1:M)
        END DO
    END PROGRAM
Compile with the Intel Fortran 15 compiler, which is according to the documentation aware of the *depend* statement. But the result printed to the screen is different at every execution. Even the initial zeros of the matrix stay at some positions. For example:
           1           2           3           4           5           6
           7           8
           0           0           0           0           0           0
           0           0
           0           0           3           4           0           0
           0           8
           1           0           3           4           0           6
           0           8
           1           0           3           4           5           6
           0           8
           1           2           3           4           5           6
           7           8
           0           2           3           4           5           6
           7           0
           1           2           3           4           5           6
           0           8
Why does the dependencies between the task do not work correctly as I expect it such that the values 1 to 8 are in each row?
Kevin_D_Intel
I see similar results with more than two threads. It appears to be a defect. I escalated to Development and will let you know what I hear back.
(Internal tracking id: DPD200413379)
Martin_K_7
I tried the same example with icc 15 and ported the code to C and the same happens.
Here is the code in this case:
#include <stdio.h>
#include <stdlib.h>
int main(int argc, char **argv)
    int M = 16;
    int i,j;
    int A[M*M];
    for (i = 0; i < M; i++) {
        for (j = 0; j < M; j++) {
            A[j*M+i] = 0;
     #pragma omp parallel
        #pragma omp single
                #pragma omp task depend(out:A[M*j]) default(shared)
                    A[M*j] = (j+1);
                for (i = 1; i < M; i++) {
                    #pragma omp task depend(in:A[M*j]) default(shared)
                    A[i+j*M] = A[M*j];
        #pragma omp taskwait
            printf("%4d", A[i+M*j]);
        printf("\n");
    return 0;
