OpenMP and !DEC$ attributes
Pellegrini__Etienne
I am using OpenMP and Intel Fortran within Visual Studio 2010 Ultimate. I am calling some functions that are exported from a homemade DLL using the attribute DLLEXPORT and aliases. I use DLLIMPORT for the importation. No problem there.
The problem comes when I try using an OpenMP sentinel (!$, without omp, as in !$ call omp_set_num_threads(4) for instance) right after those DLLIMPORT statements. The conditional compilation that is supposed to be performed by the compiler when using /Qopenmp does not work, and the statements seem to be ignored. However, if I have any standard Fortran statement between the !DEC$ and !$, no problem anymore. Same if the openMP statement is an actual openMP directive, usig !$omp instead of just !$. To resume:
      PROGRAM main
        !$ use omp_lib
        integer :: i
        !$ print*, 'OMP 1'
        !DEC$ ATTRIBUTES DLLIMPORT, ALIAS : 'func1'  :: func1
        !$ print*, 'OMP 2'
        i = 5
        !$ print*, 'OMP 3'
      end program
outputs: 'OMP 1'
              'OMP 3'
I have not found any references to this problem anywhere else, or any doc explicitly stating that an openMP sentinel should not directly follow a !DEC$ attributes statement, so I thought that maybe it was a bug that had not been discovered yet.
pbkenned1
Looks like an obscure bug with conditional compilation that hasn't been reported previously.  I'll discuss with the team and follow up.
Patrick
pbkenned1
Apparently this is a compiler front end bug, and it has been reported to compiler engineering (internal tracking ID DPD200362090).  I'll keep this thread updated with news from the developers.
Patrick
Pellegrini__Etienne
Thank you, Patrick!
pbkenned1
This issue has been fixed in a future version of the compiler.  I'll identify the version with the fix when it becomes available.
Patrick
pbkenned1
This is fixed in the 16.0 compiler, so I am closing this ticket now.
C:\ISN_Forums\U533490>ifort -Qopenmp  foo.f90
Intel(R) Visual Fortran Intel(R) 64 Compiler for applications running on Intel(R) 64, Version 16.0.0.110 Build 20150815
Copyright (C) 1985-2015 Intel Corporation.  All rights reserved.
Microsoft (R) Incremental Linker Version 12.00.21005.1
Copyright (C) Microsoft Corporation.  All rights reserved.
-out:foo.exe
-subsystem:console
-defaultlib:libiomp5md.lib
-nodefaultlib:vcomp.lib
-nodefaultlib:vcompd.lib
foo.obj
C:\ISN_Forums\U533490>foo.exe
 OMP 1
 OMP 2
 OMP 3
