OpenMP problem
fah10
Hi, I'm trying to use the new OpenMP 3.0 features. Unfortunately, the loop collapsing doesn't work when the outer iteration count equals one.
The following test program was compiled with "Version 11.0 Build 20090318 Package ID: l_cprof_p_11.0.083" with "ifort -openmp test.F90"
The execution time on one and two processors is identical, no speed-up is achieavable.
Can anyone reproduce this bug? Is there a workaround?
program test
integer(kind=4), parameter :: n=100000000
integer(kind=4) :: i,j,k
real(kind=8), dimension(n) :: d
k = 1
!$omp parallel do collapse(2)
do i=1,k
do j=1,n
d(j) = sqrt(abs(sin(cos(tan(real(j*i,kind=8))))))
end do
end do
!$omp end parallel do
print*,d(1)
end program test
jimdempseyatthecove
[cpp]program test
integer(kind=4) :: i,j,k,ij
k = 1
!$omp parallel do
do ij = 0, k*n-1
   i=(ij/n)+1
   j=mod(ij,n)+1
end do
print*,d(1)
end program test
[/cpp]
Jim
